Old 02-10-2010, 02:01 PM   #1
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Overlander Dinette
The last big project for the Overlander--get rid of that garrish organge goucho! After seeing what Uwe did for SteSpot's Ambassador, I decided the way to go is a dinette. I had previously put a small dinette in my Caravel, but had to be canted in order to get a bench long enough on one side for two people--basically it is a 3-person dinetter. I wanted more in the Overlander--plenty of room for 4, plus the ability for two to comfortably sit side saddle and watch the flat screen on the side of the fridge.
The Caravel bench is great, very comfortable, and has two drawers that are accessible as you stand outside at the door. It's big drawback is that it has a wine rack toward the front of the trailer and is accessible from under the front of the seat, which practically demands you get on your hands and knees to get any thing out. Also, the Caravel seat slopes about 3 degrees and I'm thinking I want a tad more.
So the Overlander benches are designed so that the back flips forward, the seat flips up, and the armrest rotates onto the seat--all three storage areas are accessible from the top.
The seat is 48" long and 18-1/2" wide, with a slope of 4.5 degrees, front to back (that's 1-1/2" in 21"). The back is 15-1/2" high, above the 3" seat cushion, and slopes back 14 degrees. With these general dimensions in hand, I put together the supporting box with the right slope. The backbone of the box is solid maple and all three moving parts hinge to it, so it has to be stiff. The end panels establish the slope of the seat.
Name:	IMG_0436 end panels-s.jpg
ID:	95953 Click image for larger version
Name:	IMG_0435 bench backbone-s.jpg
Two rectangles of 1/2" birch plywood complete the supporting box. The seat and back panels are edged with maple to protect the plywood and hide the plywood edges. Putting the edges on takes a boatload of clamps. Only three sides are edged with maple--the hinged edge is not edged.
Name:	IMG_0440 panel-s.jpg
ID:	95955 Click image for larger version
Name:	IMG_0439 rectangle-s.jpg
So far the construction is totally rectalinear. That got to be fit to the curved shell. I elected to construct the box so that individual small partitions could be used to make the fit, provide the offset from the shell for the storage spaces, and at the same time provide support for the back and armrest. Each one of these buggers required several trips back to the bandsaw to get them right. You can see that there is enough room behind the bench to store two folding chairs. This space would otherwise be wasted, since the back of the seat leans back. This requires about 4" of offset from the wall (at the forward end) so the forward corner of the seat back has room to lean back. This results in 9" of space at the door end of the bench.
Name:	IMG_0442 fitting to shell-s.jpg
ID:	95957 Click image for larger version
Name:	IMG_0446 storage space-s.jpg
With the back panel just sitting in place, it's beginning to look like a bench seat. You can see where the two drawers are going to go. This is a great location for tools and stuff you might need outside, since it's handy without stepping into the trailer.
Name:	IMG_0444 rough install-s.jpg
More details to follow, as I get the other bench fitted and then figure out what the heck I'm going to do about a table.
Zep
Old 02-10-2010, 03:32 PM   #2
SteSpot's Avatar
1968 28' Ambassador
1982 24' Airstream 240
Ventura , California
Looking good
I think you will like the dinette.....our bench extends past the table which gives us a place to sit that is like a couch......we wanted both a couch and dinette. We really like the dinette for eating and computer work....then I can turn sideways and put my feet up and lean back on a pillow we have against the front of the Airstream.... Uwe used a cushion behind the cushions for the back part.....we have windows that come down lower than the cushions so the shorter cushion keeps the back cushions from hitting the windows.....thanks for posting your progress. paula
Paula & Ed
Suite Spot
WBCCI # 8252 Air#13593
1968 28'Ambassador
2011 GMC Yukon Denali
1982 24'Motorhome (82Ste P)
SteSpot is offline   Reply With Quote
Old 02-10-2010, 03:38 PM   #3
SteSpot's Avatar
1968 28' Ambassador
The drawer
I forgot to mention that slide out drawer under the seat by the door.....we love that drawer......we can put all kinds of things that we need to be able to reach while standing outside the trailer.....I thought I would put shoes in there but not---it works really well.....p
Paula & Ed
Suite Spot
1968 28'Ambassador
Old 02-10-2010, 05:35 PM   #4
1975 31' Sovereign
1977 23' Safari
Thanks, Paula. Still a lot of details to take care of, like the arm rests, which are going to be a PITA.
Anyway, more progress this afternoon. With both benches temporarily fitted to the shell, I've got 27-3/4" between the edges of the seats. Thirty would have been optimum--that would have allowed the back cushions to fit perfectly in the gap to make a bed.
Name:	IMG_0448 both fitted-s.jpg
ID:	95969 Click image for larger version
Name:	IMG_0449 open-s.jpg
Zep
Old 02-10-2010, 05:51 PM   #5
SteSpot's Avatar
1968 28' Ambassador
Not sure of the year of your Overlander
But I think it may be wider than our 68.....so that would affect the measurements.....think that is why we don't have room for chairs behind.....and we don't have built in back supports.....we just have the cushions.....we needed all of the width we could get. p
Paula & Ed
Suite Spot
1968 28'Ambassador
Old 02-10-2010, 05:53 PM   #6
JimGolden's Avatar
1977 31' Excella 500
Two Thumbs UP!
Great craftsmanship, Zep!
- Jim
JimGolden is offline   Reply With Quote
Old 02-10-2010, 07:49 PM   #7
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Attachment 95969 Attachment 95970
Zep
Why not go with foam 1" thicker than you planned to use, that would eliminate 1" from each verticle cushion and then your bed math would work out just fine. (Craftsmanship is awesome BTW Roger)
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 02-10-2010, 08:03 PM   #8
1975 31' Sovereign
1977 23' Safari
Wow, I never thought of not having the back supports! Sheesh. But I do like the storage for folding chairs--they come in handy under the new awning.
My Overlander is 88-1/2" wide at the "C" channel. About 91" wide at 30" above the floor.
Zep
Old 02-10-2010, 08:08 PM   #9
1975 31' Sovereign
1977 23' Safari
Scott,
That's actually a really good idea. I'm a little bit concerned about the total height. At 14-1/2" the Caravel is totally comfortable. This bench is 1/2" higher. Doesn't seem like much, but if you're shorter than 5'-6" the 15" seat height (without cushion) might be too much. I'll have to put a cushion on it to find out.
The other solution is to slide the benches a few inches aft of where they are now. That would take the forward corners of the benches out of the corner of the shell, allowing them to move outboard. I hate to throw away those vertical panels (since they are soooo nicely fitted now), but maybe that's not a huge expense. I have room to move the benches aft about 3".
Zep
Old 02-10-2010, 08:18 PM   #10
I'm so glad you're doing this, Zep. I'm planning on a dinette for my 63 Overlander in the near future, and I love looking at your work, so it will be great to see your approach and solutions on this challenge.
I have the low front windows both curbside (jalousies) and streetside (double-height windows) so formed wooden backs won't be possible on mine. I'll have to do something similar to what Uwe did on his 63 Olander with only cushions for backrests. I'd love to be able to have some storage behind there and use it for my lawn chairs as you have demonstrated, but I'll just have to figure out something else.
However, I definitely plan on the same access panel on the curbside bench right by the door that you have put in there. It will be very convenient for stowing items without climbing in and out of the trailer.
Old 02-10-2010, 08:19 PM   #11
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Thanks for posting your progress. Working on a similar project for our Tradewind.
I was going with a curbside drawer as well. Figured it would be a great place to store all the stuff you need for the initial set-up.
Did you cancel the lower non-opening side windows? I found they put a crimp in the overall design possibilities. I had to opt for a narrow shelf with the backrest cushion extending past the top.
Please keep us posted on your progress.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 02-10-2010, 08:32 PM   #12
1975 31' Sovereign
1977 23' Safari
Tom,
You'll see that I'm sort of anti-window. I only want them for the breeze. If I want to look outside, I tend to go outside.
Removing wing windows: http://www.airforums.com/forums/f454...tml#post763274
Removing Vista Views: http://www.airforums.com/forums/f454...ews-32184.html
Removing lower windows: http://www.airforums.com/forums/f454...gin-34135.html
Some of these threads show the work that was done on the Sovereign, but I did the same to the Overlander. I tend to spend time in hot locations and the small upper and lower windows just let in the heat, as far as I'm concerned. And the lower ones get in the way of new furniture!
Zep
Old 02-13-2010, 07:08 AM   #13
TCM1's Avatar
1975 31' Sovereign
Drasco , Arkansas
Nice work. I plan to follow your lead on my '75 International. Keep us posted. TCM
TCM1 is offline   Reply With Quote
Old 02-24-2010, 07:33 PM   #14
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Unbelievably, I missed this thread altogether. Thanks to Utee I found it. As usual, Zep, your work is fabulous. Keep us up to date.
www.nesa.org
Air No. 6427
Why no dinette ? Robbie R. 1998 Excella 1000 3 08-17-2009 05:58 AM
Front Dinette for 1964 Overlander 64Overlander Cabinets, Counter Tops & Furnishings 6 07-12-2009 12:32 PM
Dinette value jfowler218 General Interior Topics 16 01-12-2009 11:09 AM
Dinette... Auretrvr Classic Motorhomes 1 09-11-2006 08:40 AM
68 Overlander with a Dinette Uberlanders Upholstery, Blinds, Walls & Interior Finishes 12 08-27-2006 12:04 AM
