Old 06-18-2010, 05:59 AM   #1
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Overhead Locker Door Stays - Spring Cylinders
I'm looking for replacement overhead locker door stays. It is the spring loaded "cylinder" that keeps the wooden door up. I'm tired of using my head to keep the door open while I put away the dishes! Has anyone found a source for this part?
David
Old 06-20-2010, 04:46 PM   #2
Funny, we were just looking for the same thing for the overhead doors in ours. We found 3 different ones at CamperWorld.
Old 06-20-2010, 07:13 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Try your local auto parts store. They usually have quite a selection, another source could be an industrial supply house like Grainger or McMaster-Carr. I know that my WeatherGuard tool boxes use them.
Aaron
WBCCI #XXXX AIR #2495
Old 06-21-2010, 05:50 AM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thank you for the tip Tadd and Beth. I'll check at Camping World for it. I was hoping for a direct replacement so I wouldn't have to drill new holes.
David
Old 06-21-2010, 06:57 PM   #5
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
If you have an Airstream dealer, you can readily find them. If you do not, the Inland Andy will be glad to fill your order.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 06-21-2010, 07:11 PM   #6
BTW - The link I put up above has 3 versions but only 2 are the full stays. The one listed as "Metal" is only the cylinder and one side mount. I wanted to order metal ones rather than plastic but had to call because the photo was funny. That is when they explained it was only a replacement part, not the hole stay. We ended up getting the more expensive of the plastic ones. I can post back after they arrive next week if you want feedback on how they work.
Old 06-22-2010, 05:42 AM   #7
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thank you folks for the information. I did get a call from Inland RV and they have the direct replacement cabinet door support at about $9.00 each. I will place an order with them. Inland RV has been helpful to me for direct replacement parts for my 86 Airstream.
David
Dometic 2800 door latch spring artnsue Refrigerators 1 04-24-2007 05:54 AM
overhead/door latch help?? manley General Interior Topics 2 03-10-2005 03:30 PM
OUCH! overhead cabinet door lumps baldeagle Cabinets, Counter Tops & Furnishings 5 01-25-2005 01:16 PM
Need spring load clips for water heater door 68 GT. Jim Clark Water Heaters, Filters & Pumps 4 05-09-2002 08:39 AM
