Old 03-25-2019, 05:32 PM   #1
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
No-Hinge cabinet doors
For full access to deep cabinet space, I recommend doors that can be moved out of the way. I make doors that are held in place by "pins" and a strong cabinet catch. A wooden rail on the back of the door provides a location for two screws that act as the pins. Be careful to keep the "pins" short or they can break the cabinet rail if they are long enough to act as levers as you rotate the door out.
The two precisely located drill holes in the cabinet rail receives the pins.
Name:	hingeless receivers.jpg
The catch at the top of the door could be magnetic, but I did that a few years ago and occasionally the door would pop out while towing, so I'm using these stronger catches this time.
Name:	hingeless catch.jpg
The installed door looks pretty normal.
This Airstream goes into the dusty desert, so I put seals on the back side of all my doors.
Name:	hingeless seals.jpg
Replacing Tambour doors with sliding doors Shermy1987 Cabinets, Counter Tops & Furnishings 1 08-29-2018 06:02 PM
Tambour Doors - Like New - Full set of aluminum finish doors with hardware from 2015 16' Airstream copenagle Airstream Classifieds 0 09-04-2017 03:08 PM
'69 hinge window and access doors Harperbear Windows & Screens 2 12-02-2015 01:14 PM
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-20-2010 11:39 AM
