02-15-2016, 08:47 PM
1978 25' Tradewind
Metro Phoenix
New upper cabinets going in!!
Knotty alder face frames. red birch 1/4" paneling. Doors will match lower cabinet doors, hinged at the top with pneumatic struts.
02-19-2016, 09:34 PM
1977 31' Excella 500
Dallas
Nice work. How did you attach the cabinets to the walls?
03-30-2016, 04:05 PM
1978 25' Tradewind
Metro Phoenix
Sorry for the delay!
The horizonal part is attached to the outboard wall with pieces like this. The angle cut is (more or less) the same as the wall angle at that point.
I made the screw "holes" with a Kreg jig and used regular Kreg screws into the aluminum wall.
The vertical face frame is attached to the roof with a 1-1/2" x 1-1/2" by 1/16" aluminum angle strip. The angle is compensated-for with a wedge-shaped strip of the alder.
03-30-2016, 04:09 PM
1978 25' Tradewind
Metro Phoenix
Finished cabinets!
The end boards are just held on with angle brackets.
03-30-2016, 04:20 PM
1978 25' Tradewind
Metro Phoenix
...and the struts:
50 newton struts, only one needed per door.
03-30-2016, 04:58 PM
1972 31' Sovereign
Lexington
Looks very nice!
Kay
03-31-2016, 07:45 PM
1978 25' Tradewind
Metro Phoenix
Originally Posted by Minno
Looks very nice!
Kay
Thanks!
07-21-2016, 12:46 AM
Black Diamond
Drboyd, where did you get the aluminum trim for the end board? Does is bend easily without too much deflection on the corner? Cabinets look great.
07-21-2016, 08:19 AM
1978 25' Tradewind
Metro Phoenix
I got that trim at Orange Aluminum in greater Los Angeles. It bends easily by hand around the corners.
And THANKS!
08-20-2016, 10:03 AM
1978 31' Sovereign
Euless
You mentioned that you obtained the end trim pieces from Orange Aluminum. when I went to their website I did not find the flexible aluminum trim in your photo. Do you have a description or stock number?
08-20-2016, 07:12 PM
1979 23' Safari
Wayland
, New York
Looks great! How did you attach the bottom to the back of the face frame?
08-20-2016, 08:01 PM
1978 25' Tradewind
Metro Phoenix
I believe it was OA7428-6 from this page.
They don't refer to it as "flexible," but it is bendable by hand.
08-20-2016, 08:04 PM
1978 25' Tradewind
Metro Phoenix
I did a "rabbet" or "dado" (I'm not sure what to call it) cut 1/4" wide about 1/2" deep roughly 3/8" of an inch up from the bottom of the face frames.
