Old 09-08-2019, 02:26 PM   #1
JoeyOC
joeyoc's Avatar
San Clemente , CA
New Table is Wobbly - Suggestions Needed
Hi there! I just purchased a 1961 Overlander...I'm new to Airstreams. We pulled out the couch/bed setup and installed a great wrap-around booth with a great table with a fun checkerboard that a friend handcrafted. The table drops into the bed section. (See photos)
Our problem is that the table is really wobbly. We can cut the removable pole to make it a bit less wobbly, but I was wondering what my options are?
We had first looked for an adjustable pole for the table, but found very few options on Amazon. We purchased an adjustable one for $170, but it was way too high and the manufacturers measurements were way off, so we opted for a fixed position pole (in the photo).
I know we can do a two-pole setup for stability, but haven't found any for sale online. We are going to rent this Airstream out, so we don't want the table broken from rough-housing or people sliding in and out of the booth.
How have other people resolved this issue?
Ideas welcomed! Thank you!
ID:	351699   Click image for larger version
joeyoc is offline   Reply With Quote
Old 09-08-2019, 08:39 PM   #2
Silver Dreams
1988 34.5' Airstream 345
Columbus , OH
Originally Posted by joeyoc View Post
...I know we can do a two-pole setup for stability, but haven't found any for sale online. We are going to rent this Airstream out, so we don't want the table broken from rough-housing or people sliding in and out of the booth.
Nice job Joeyoc! It looks very similar to the project that we just completed, where we installed an inexpensive electric table lift purchased online at AliExpress. It comes from China, but only takes a couple of weeks for delivery. So far it's working really well and makes the conversion into a bed or vice versa simple. If you order it, just make sure you select 12v. We got model B, which is the heavy duty one and easily supports the solid walnut table we had made.The kit comes with a wall mount switch and a remote. Installation is straight forward. Good luck with the rest of your renovation.
Here's the link: https://www.aliexpress.com/item/32815565645.html?spm=a2g0s.9042311.0.0.5f144c4dyjt Ekxem/32815565645.html?spm=a2g0s.9042311.0.0.5f144c4dyjt Ekx[/url]
Name:	Rosie rear table.jpg
1988 345LE "Rosie"
-Jerry
stream3 is offline   Reply With Quote
Old 09-08-2019, 08:46 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
You need is a much larger "post" if you are going for a single support design. The alternative is to latch one side to the wall of the trailer and get stability that way. The issue isn't just how much it wobbles. You also need to support that bag full of beer ... errr ... groceries that gets put on one side of the table.
Old 09-08-2019, 08:59 PM   #4
JoeyOC
joeyoc's Avatar
San Clemente , CA
Hi Jerry,
Thanks so much for the great lead on the table lift...I had search all over for these. I did go to the site and it wasn't clear to me the lowest height it goes to?
A couple questions:
1. Did you just mount it into the floor with woodscrews? No going deeper into the subfloor to get it lower (like other tables we've seen).
2. Our Airstream is only on 110 (no 12v at all). How did you run the wiring? Your unit looks really nice, but I'm wondering if we're going to have a power issue? We do have a 110 outlet nearby, but it would look awkward plugging in in. We did build a lot of storage seats under the bench seats, so there could be a possibly to run wiring through there?
It looks like a great option, the base is much wider and I will definitely consider it...the price is right!
Thanks so much,
Joey
Old 09-08-2019, 09:00 PM   #5
JoeyOC
joeyoc's Avatar
San Clemente , CA
Hey Bob,
Thanks for your reply. Agreed not stable to support groceries or beer, let alone the beer wobbling off the table. Any idea were to source wider bases?
Thanks again,
Joey
Old 09-09-2019, 09:12 AM   #6
Half a Rivet Short
Hey Bob,
Thanks again,
Joey
Hi
The base is not at all a common item. They are pretty RV DIY specific. I have never seen a "proper sized" one, but they must be out there somewhere.
One option would be to buy one as a replacement part from JC. You might have to go through a dealer to get that done.
Old 09-09-2019, 11:50 AM   #7
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
Joeyoc
Looks like one model lowers to around 12 inches and raises up to 28 inches and runs on 110v . Looks like it would work for you.
Streamracer is offline   Reply With Quote
Old 09-09-2019, 01:29 PM   #8
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
You might consider changing out the hardware. We used this one: https://www.westmarine.com/buy/imtra...ck--P017190836
It's rock solid and the bump on the floor is minimal.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 09-09-2019, 01:37 PM   #9
1993 25' Excella
Valley Village , California
I've created a replica of your dining area in our '93 Excella ... and created the same problem.
I had a different bottom "receiver" bracket that set down into the floor about 3" (rather than sitting on top of the floor like yours does). I was afraid to use it as I don't know how much room there is under the floor (have only had ours for 6 mos.) so I used one just like yours and it wobbles (spilled coffee already a few times!).
Now I'm wondering if that "inset" bracket would be more stable? Anyone know?
stevesiegel is offline   Reply With Quote
Old 09-09-2019, 02:03 PM   #10
tojimmiller's Avatar
1996 30' Limited
1990 34.5' Airstream 345
santa rosa , California
Very nice
tojimmiller is offline   Reply With Quote
Old 09-09-2019, 02:12 PM   #11
Silver Dreams
Columbus , OH
[QUOTE=joeyoc;2286525]Hi Jerry,
Lowers to 12" and raises up to 28". It's perfect for our bed and table height.
A couple questions:
Ours is a Classic motorhome so I couldn't speak to your floor. We ran 4 bolts up and through with a custom frame around it to secure.
It's hard wired, but if you already have power nearby then wiring it up shouldn't present any real difficulties.
1988 345LE "Rosie"
-Jerry
Old 09-11-2019, 05:55 PM   #12
JoeyOC
joeyoc's Avatar
San Clemente , CA
Yes indeed...the size looks right height-wise. Now I need to figure out how to run the power? I'm only on 110...hmm, any suggestions!
Old 09-11-2019, 05:57 PM   #13
JoeyOC
joeyoc's Avatar
San Clemente , CA
Ahh...I didn't read this thread Jerry...scrolled too fast.
My Airstream is a 1961 and I don't think I want to mess with the subfloor to make it work...don't want to mess it up. You bolted yours...I don't know if it would stay with only wood screws?
Old 09-13-2019, 10:48 PM   #14
JoeyOC
joeyoc's Avatar
San Clemente , CA
Thank you Janet! I'll check it out!
Joey
Wobbly dinette table - 30FB bunk Denali81 2016 - Current Flying Cloud 0 09-30-2018 10:23 PM
Wobbly Kitchen Table chaseav 2011 - 2015 International 10 05-14-2016 09:03 PM
Wobbly Table Loden Eddie Bauer - All Models 5 09-02-2015 06:41 PM
Wobbly Table photobug47 General Repair Forum 2 08-28-2014 10:51 PM
Wobbly dinette table flyfishfred Cabinets, Counter Tops & Furnishings 4 01-21-2008 10:19 AM
