Originally Posted by darlingbooks
Is your water filter easy to change out? Steve
Yes it is easy to get to and change the filter, there are 2 connection, one at each end that you pull out and the filer comes right out. There is also a hose with the same connections as he filter that you can use for winterizing with the pink stuff.
I am going to make 2 sink covers out of the same corian type material with a cutting board mounted on the underside cut to fit the sink opening as soon as I can get to it. The sinks are good and deep but sill leave storage rome under them.
Don
