Yes, sometimes you might have to make them smaller to show up on the forums...when you want to post photos you will click on the post reply tab
(not the post quick reply)
and then you will go to the tab that says manager attachments to post your photos.
Using the photo gallery -- I'd sure recommend setting up your own 'Member's Photos' if you want to find the pictures again. The other categories are in chronologic order and tend to be hard to find after a period of months.
What an awesome job you've done with the Airstream. Love the colors you chose as well!
I can't wait to see the next issue of Airstream Life the picture of you with the palm trees and surf boards is very cool...
Originally Posted by kennyp315
Thanks for the help. These are some of the photo's in next issue Airstream Life. The next post is what I started with, Kenny
Hey Steve, I used birch veneer for for the walls, ceiling and finally to cover all the cabinets. It was a long and tedious project. At one point, due to humidity, the ceiling started to bubble. I was totally sick. Thinking that I had done all that work for nothing. I rerolled the ceiling over and over finally getting it to re-stick. I then immediately sealed the veneer with sanding sealer. That did the trick. Don't use 1/8" ply as it will not work on the compound angles. I tried many times to use it and cut the cost of the veneer. Also, if you veneer, make sure that you order it with the same grain pattern (one tree) so that your grain lines up. Good luck. Kenny
Airhog,
Your first two posts in this thread are supposed to contain pix. But there are no pix there any longer (or maybe never were).
What's up with that? Can you please re-place them?
BTW you are still shown as a dealer. Are you back? I thought you were boilin' footlongs for Sonic.?????
Did you get to Arlington for the blowout? Please take A&M's coach along with Jerry Jones, his "cowgirls" and the new monstrosity of a stadium back to the hills of Arky forever.
