Old 02-17-2014, 06:39 AM   #1
mrs.dawdy5's Avatar
Need to remove!
I need to remove the cabnets over the twin size bunk in my 1969 stream line can anyone tell me if there is a way to do this without having to replace the dang inner skin or damaging it. (If I have to damage the hidious carpet on the wall in this section I promise it will not hurt my feelings) lol
mrs.dawdy5 is offline   Reply With Quote
Old 02-17-2014, 09:15 PM   #2
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
I have zero experience with Streamlines-- but I think they are cool! If (and this is a big if) they are hung like many Airstream cabinets they are probably riveted to the ceiling/wall. They may also be screwed or riveted to a cleat or bracket. If you drill out the rivets and keep looking for hidden ones you should be able to get them down without damaging the walls. If you out them back you can use the same rivet holes. If you leave them down you can fill the holes with rivets. For wall- hung canisters this job is much easier with a second person.
Skatiero is offline   Reply With Quote
Old 02-17-2014, 09:39 PM   #3
mrs.dawdy5's Avatar
Yup rivets everywhere lol I'm so glad u told me that I was ready to just say screw it and have to replace the inner skin lol.
How do I remove the belly pan? aluminitus Belly Pans & Banana Wraps 19 10-21-2014 10:50 AM
Can't remove the gas tank Buttercup Classic Motorhomes 14 12-02-2011 09:03 PM
Anyone tried to remove a 1977 Argosy Fridge synhorst Refrigerators 2 09-25-2011 03:36 PM
RemovAll 220 - will it remove old caulk? malconium Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-21-2011 08:26 PM
How to remove slip hub / flange 1970 3/4 bath silversafari Waste Systems, Tanks & Totes 2 02-27-2011 07:40 AM
