Old 08-09-2011, 11:11 AM   #1
TankerIP's Avatar
2002 22' International
Need to fix separated wall panel
A few spots on our trailer have wall panels that have come loose from the furniture frame. It looks like these panel/veneers were originally afixed with short staple guns. I would like to make them stick a little more permanently but still have them look attractive.
Anyone have a suggestion of what kind of fastener I could use that would look good and still be secure? Maybe some kind of elegant screw?
ID:	137135   Click image for larger version
TankerIP is offline   Reply With Quote
Old 08-10-2011, 07:50 AM   #2
Dan@LED4RV's Avatar
Denton , North Carolina
right track
Originally Posted by TankerIP View Post
........... look attractive.
I have seen this before. I would pre-drill the holes to make sure it does not slip or split. It may not be very easy to find srews the same color and painting the heads of ones you like may be easier. I would also use some glues like Liquid Nails if you have surface to stick it to. The glue and screws should give enough strength to keep it from coming loose again.
If it comes back loose again it will look real bad. Over-kill to make sure that does not happen is a good idea.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 08-11-2011, 08:08 PM   #3
TankerIP's Avatar
Thanks for suggestion. I think I will see if I can call someone in Jackson Center. I noticed elsewhere in my trailer that there are screws in the panels with a cover over the head of the screw. I would like to get some of those to use.
Now I need to figure who to call or write at JC.
Old 08-11-2011, 08:56 PM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
Those might be called Snap-Caps. I get them at auto stores or on line. I paint them to match my project. Rockler or Hobby Lobby probably has them too.
Wide White Wall Tires wasagachris Tires 14 08-04-2011 09:32 PM
Hybrid fuse panel pgr32e Batteries, Univolts, Converters & Inverters 1 07-14-2011 09:56 PM
wall covering??? leather, Wall paper Josh Loki General Interior Topics 1 07-02-2011 10:16 AM
Wall Covering Pictures Roadrunner Upholstery, Blinds, Walls & Interior Finishes 7 05-19-2011 10:50 AM
Interior Wall Structure Strip chowman2011 General Interior Topics 3 05-17-2011 08:09 AM
