Old 01-29-2014, 10:50 PM   #15
1978 25' Tradewind
Sacramento , California
To PERRYG114,
I am currently redoing a 1978 International Tradewind. Just got my tambour 4' x 8' sheet by UPS. Very nice quality and the back material is some synthetic fabric that is much hardier than the original backing, see pics. Same exact thickness and slat width. Not bad for the price of $150 shipped. Some AS specialty sites are charging $600 + for similar stuff. Will spray paint and then cut to size on the table saw. We'll see how it turns out.
samvogt is offline   Reply With Quote
Old 01-30-2014, 06:35 AM   #16
1973 25' Tradewind
Augusta , Georgia
Originally Posted by webspinner View Post
It should work, as long as none of the slats in the new "tambour" are wider than the original slats.
The replacement piece is about 3/4" wider than what I need. I plan to solve that using the table saw and VERY GOOD panel blade. I didn't want to spend the propane to heat the shop up yesterday so that project is on list for Saturday.
Back to Normal Grid now that Southeast in thawing out
DGJackson is offline   Reply With Quote
Old 01-30-2014, 06:47 AM   #17
1981 31' Excella II
New Market , Alabama
Is it solid wood or some sort of veneer on it? Hard to tell from your pics. Do you have the part number for what you ordered? Let me know how the cutting on the table saw works out.
Perry
Originally Posted by samvogt View Post
To PERRYG114,
Attachment 204619
Attachment 204620
Attachment 204621
Old 01-30-2014, 09:10 AM   #18
garthbf's Avatar
1975 31' Sovereign
1960 26' Overlander
Mount Vernon , Washington
here is a guy selling some on craigslist.
Airstream parts vintage trailer
garthbf is offline   Reply With Quote
Old 01-30-2014, 09:30 AM   #19
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Try here
Search results for: 'tamber'
Old 01-30-2014, 09:37 AM   #20
Okiestreamer's Avatar
1999 25' Safari
Adair , Oklahoma
Thanks garthf. I sent him an email. He posted it on 1-4 so he may have already sold it.
Dave
Okiestreamer is offline   Reply With Quote
Old 01-30-2014, 03:38 PM   #21
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
I hated the tambour on the lower cabinets in my previous 72' Overlander, so I removed them and created full doors. Pretty easy to do, just time consuming... as is everything with our Airstreams. I built simple lightweight frames from 1 x 2 pine, filled in the centers with 3/4" foam insulation, then laminated both sides with Formica. Then I put aluminum angles on the perimeter and piano hinges to connect to the cabinet frame.
I plan to build similar type doors in my new 77' Sovereign (if I ever get that far )
ID:	204639   Click image for larger version
My 77 Sovereign Renovation
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 01-30-2014, 04:47 PM   #22
1972 21' Globetrotter
Wylie , Texas
Ok, I am good at thinking outside the box and doing things on the cheap. This may not be for everyone, but here's an idea. I pulled the nasty carpet and replaced with this bamboo flooring. It is very similar in size to the tambor strips, which is partly why I liked it as a matching look among other things. The strips are connected to a thin poly backing (which is not the best). But it does hold it together and it can be rolled very tightly because that is how it comes. It was thin enough to fit under things easily and can be cut with utility scissors. It may be a little flimsy, but with the right backing (canvas?) could be made to work for some. It can also be stained because they come in different colors. I purchased mine last year at Ross discount stores for less than $20 per 4x6 ft rug. They also have smaller sizes. You can also find them for a little more at world market. I have not tried it as a tambor. In fact I am not a big fan of them and will be removing mine as I get into the interiors. I'm sure they were great in their day, but my vote is for doors also.
Great work sneakinup, first class!
rippie is offline   Reply With Quote
Old 02-04-2014, 04:46 AM   #23
shadeemry's Avatar
1975 31' Sovereign
cary , North Carolina
Need Tambour Help
You can prevent this from happening by waxing your tambous. Can also help to unbind them as well.
shadeemry is offline   Reply With Quote
So when did Tambour Go Away perryg114 Cabinets, Counter Tops & Furnishings 18 02-18-2012 07:51 PM
frosted coil up panels to replace tambour cabinet faces colsons Cabinets, Counter Tops & Furnishings 0 05-17-2011 11:50 AM
Where can I get a tambour door for my '72 overlander? JackP Cabinets, Counter Tops & Furnishings 4 04-13-2011 11:42 AM
Aluminum tambour Betty3117 Cabinets, Counter Tops & Furnishings 8 03-20-2011 02:44 PM
Want to replace kitchen tambour doors Gkiesel Cabinets, Counter Tops & Furnishings 0 03-13-2011 06:33 PM
