Old 06-16-2015, 11:04 PM   #1
2004 30' Classic Slideout
Denver , COLORADO AND West Yellowstone, MT
Need Shower Door "Locking" Knob for 2004 Classic
I am the proud new owner of a 2004 30' Classic with a slide-out. Since our purchase, I have been looking for a knob/lock for the shower door (gold anodized aluminum frame and door) which was loose and broken. I think this knob is supposed to latch inside the shower and prevents the door from opening during travel. I can't find one anywhere. We have been using duct tape as a standby, but would like the real thing.
Any suggestions about where to find one. I think it was brown bakelite plastic or similar.
Thanks in advance.
montanapat
montanapat is offline   Reply With Quote
Old 06-17-2015, 04:32 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Have you tried any Airstream dealers?
Old 06-17-2015, 06:33 AM   #3
Missouri Valley , Iowa
Pat,
The part number is 381403. I saw it on ebay but it said the listing had ended. The date was June 4, 2015. It was $12 with $2.50 shipping. It may be worth a try to pursue this a little further. Good luck.
Dan
Farmer Dan is offline   Reply With Quote
Old 06-17-2015, 08:00 AM   #4
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Airstream changed the shower door lock mechanism for 2007. Prior to 2007 they used a different latch p/n 381403 which they no longer make and are very hard to find. If you can't find one, you may need to be fabricate something (other than duct tape!). I'm not sure what the difference between the old latch and new latch are, or if you can modify the new one to fit, but I do know it's not a direct replacement.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 06-17-2015, 08:08 AM   #5
2004 28' Classic
austin , Texas
We have 2004 Classic and had same problem. Never found solution. In the end bought new shower door...also to get rid of gold metal.
Ntex is offline   Reply With Quote
Old 06-17-2015, 11:56 AM   #6
2005 31' Classic
Gretna , Nebraska
Shower door latch
I fabricated a latch from a 1" aluminum strap (Lowes). I will try to take photo and post it here.
It is about 9" long and hangs over the door with the tail end in the shower. The important part is bent over the top of the door and the right margin is bent in to fit between the door and jam.
It needs to be carefully bent so it does not work up and fall into the shower.
Dwight
16595 is offline   Reply With Quote
Old 06-17-2015, 04:33 PM   #7
Richard
2006 30' Classic S/O
Merced , California
You will never find it. Make your own. ACE Hardware has radio knobs that will work for the outside and you make the rest. Also note: there is a slider forum somewhere on this site.
kleimanr is offline   Reply With Quote
Shower Door "Lock"/Knob montanapat Doors & Locks 0 06-07-2015 11:07 PM
1963 / vintage "push pin" "twist knob" drawer / closet door hardware Zstream General Interior Topics 3 08-25-2013 01:21 PM
Locking Aluminum LP tanks on a "Classic" brownm3 LP Gas, Piping, Tanks & Regulators 16 03-24-2013 11:12 AM
HELP!! Need pic of Armstong A/C "sticker" and knob! cobra93 Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-10-2008 08:01 PM
