Need more Sleeping Space! Need bunk starting point...
We need another sleeping space for our new-to-us '78 Tradewind. We have 2 kids.
It has the couch/double bed at the back. My thought is to take the overhead cupboards out (the ones over the couch/bed) and add a bunk.
Gulp! Now I don't know where to go/what to do.
We're newbies AS and to trailer life... so don't assume we know anything!
Ideas rollin' around in our heads (after reading previous posts):
- have a cabinetry maker create some custom bunk
- go to an RV service place (ie, someone who'd know how to keep it "light")
- is there a way to order actual Airstream bunk parts??
- leave the fold-out couch/bed and just add a bunk... um from the ceiling? from the outer wall? or....
- remove the fold-out couch/bed and create two twin bunks there?
I saw in an old post the pics of the canvas bunks suspended by cables in a late 60's model. That was an interesting idea.
Again, is there a way to order actual Airstream bunk parts? I'm new to this and can't seem to find that by googling. (Have to balance "surfing for info" with "actual work in the trailer"-- oh, and keeping "regular life" going meanwhile! LOL)
Thanks in advance for your help. It seems that this question (figuring out how to create another sleeping space) will dictate how we proceed with everything else (flooring, new cushions, etc!!!)
We need pointing in a direction and ideas for possibilities.
Greetings ByTheBay!
Welcome to the Forums and the World of Vintage Airstream Ownership!
I am afraid that the hammock bunks in their various forms dating from the 1960s and the 1970s have been out of production for quite some time. About the only way to get a factory bunk is to find a coach in a salvage yard that has the complete bunk -- the problem is that the bunks were quite often separated from the coaches early in their lives. The factory hammock bunks were separated from my coach ('64 Overlander) by the second owner who purchased it from the original owners in 1980.
I am not certain from reading your description whether you are wanting to add a bunk above a center double bed or over the front lounge. The more feasible option would be to work with the center bedroom location as you won't encounter the addtional problems posed by the ABS plastic front endcap. A cabinet maker or skilled finish carpenter could surely construct an attractive bunk -- I would hesitate to have a dealer make this type of modification -- I had my favorite dealer replace a cabinet side panel when my new refrigerator went in and ended up having a cabinet maker install a new panel as the one from the dealer just wasn't up to the quality of the factory cabinetry in my Overlander. if you decide to go with a cabinet maker, be sure to advise him/her that it is necessary to anchor to wall ribs as well as the floor -- if it is just anchored to the wall, the anchor will eventually pull out.
Good luck with your investigation!
Kevin
P.S.: I don't believe that Airstream ever offered the "cabinet bunks" that were a familiar feature in many box-type trailers of the 1960-1980 time period. The various forms of the cable suspended hammock bunks were the usual option. In the 1960s trailers, I am aware of at least two that were customed ordered with twin bunk beds in the center and no roof lockers in that part of the coach.
Kevin D. Allen WBCCI (Lifetime Member)/VAC/Free Wheelers #6359 AIR #827
The idea I am toying with is too go thru a military supply/salvage person and get the bunks used in cargo planes to install in the trailer, when I was in the Air Force these are the beds we used when transporting troops on C141, C130 planes. These are aluminmum framed and look just like a folding cot but do not fold, only require 2 connections on the rear and 2 cables or legs on the front, the bottom cot actually has legs on each end that attach to the floor. Another thought is to use the same thing as above but leave the legs on them and just let them set on top of the current bed and attach to the bed frame, thus doing away with attaching to the wall or ceilling. These cots are made to hold a 300 lbs person so they could actually hold an adult.
We have the rear twin beds so this would give us 2 more beds in the rear.
We have 5 grandchildren with 1 on the way, 3 that currently travel with us and 1 more that is going to be of age in the next year or so to travel and this set up would give us 4 beds in the rear and the couch/bed in the front for wife and I.
I dont want to make any changes to the living room area because you never know when you are camping that you may have company.
Of coarse if I get the 34 FT I want this would relieve many of my problems.
How do I know where the safe points are in the wall structure to affix it, that will bear the weight?
(ie, in a "regular" house one would use a stud finder.... what is the skeleton of the AS?)
And how much weight would the AS structure support? In other words, would there be enough support to have a hanging/floating bunk? or is it necessary to have the floor helping in that support? (I would like to have something that would support 120lbs at least)
(Hope I'm articulating my structural question well enough... pooped out today from pulling out the dirty old carpet....)
I like your idea Sarge...Im thinking about adding a bunk over the street side bed in our 31'...that would be PERFECT! Let me knwo if you find any!
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XX
Will do, as soon as my problem with AS is solved and I have more idea on what is going to happen with this trailer or is it going to be replaced.
I will also contact some people I know and see if I can get ahold of some from the Air Force yard in AZ.
Thanks, Purman, what a coincidence... I had already shown my hubby your pics! Nice bunks!
My first thought is that I want to leave the original pullout double in and create something over the top of it.
The other thought is pulling it out and doing the two bunks.
How did you attach to the wall/floor? (or, geez, perhaps I need to read and not just look at your pics! tell me if you have already described it somewhere... I was skimming for the pics... and could've spent hrs doing that!!)
I was going to post an ad in the classifieds but decided to do this first. I am finally selling the bunk from my 1975 25' tradewind. Of course, this is a little complicated as the bunkbed is in Portland, Oregon, and shipping it will cost an arm and a leg with some other body parts thrown in. It does have all the hardware except for the ceiling clips which are in the trailer - in Mexico! See, complicated.
Anyway, the bunk is in great shape and my friend who is storing it will send pictures to anyone who's interested.
I do have a pic of the bunkbed in the trailer and I can send that (can't figure out how to attach it to this here post).
And not to further complicate things, but I have no idea what to ask for it. Seems there aren't a lot around to use as a reference.
annette Amado AZ 1975 Tradewind 1997 E350
The OEM cot type bunks come up occassionally on ebay, but are pricey and probably will need new fabric.
I made a canvas bunk from aluminum tubing and marine hardware which did the job until I got 2 OEM bunks. In my Tradewind I use 2, one over each gaucho. If you are interested I will sell the first bunk cheap. There is an old post somewhere in the forums with a photo, but I have lost track of where.
Pay no attention to the man behind the curtain- WoZ
