Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 08-07-2008, 04:46 PM   #1
Nixon66
Nixon66's Avatar
Profile:  Burnet , Texas
Need help with Excella folding table
I bought an Excella folding table on eBay to install in my 78 Silver Streak. I have seen pictures of it installed in its original application and it appears that there is some kind of shelf unit mounted to the wall to aid in tucking away all the table parts when it is down. As indicated in the pictures all I have is the folding table and legs. Can someone send me measurements, diagrams, close-up pictures or even napkin drawings of what I need to build to get this to mount and work in my trailer? All answers would be greatly appreciated.
ID:	65261   Click image for larger version
ID:	65263   Click image for larger version
Nixon66 is offline   Reply With Quote
Old 08-07-2008, 04:54 PM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Riverside , California
Here are a couple of pics. Let me know if you would like any others, better detail, different angle, etc, as I am sitting at the table now.
Name:	folding table 001.JPG
ID:	65265   Click image for larger version
Name:	folding table 002.JPG
Name:	folding table 003.JPG
Old 08-07-2008, 05:05 PM   #3
doorgunner
INSANITY CENTRAL
doorgunner's Avatar
Profile:  1986 32' Excella
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
I have some pics in my member photo area of the inside of my 86 Excella, uses that kind of table.
You really need the rail that screws to the trailer wall/side, that allows front/back positioning of said table.
www.popasmoke.com
Proud Appellation American
Vine View Heights
Museum Curator
doorgunner is offline   Reply With Quote
Old 08-07-2008, 05:09 PM   #4
ArtStream
Tramp Streamer
Commercial Vendor
ArtStream's Avatar
Profile:  1995 28' Excella
Artist , at Large
Images: 58
It is a very arcane system.
After taking one apart I was baffled trying to figure out the logic behind it. But like many things Airstream, it somehow functions .
Hi Terry!
Artstream Art & Tee's
by Micheal Joseph Depraida
WBCCI No 8892 | VAC | KC2TQU
ArtStream is offline   Reply With Quote
Old 08-07-2008, 05:22 PM   #5
overlander63
Hi Terry!
Hi, Michael. One of the things in the pictures I posted was of that sliding pivoting thing. I can post a little better pic if needed.
Old 08-07-2008, 06:24 PM   #6
Nixon66
Nixon66's Avatar
Overlander63,
I think your pics are good enough. Now I know what I suspected. I am going to have to fab something up for my purpose but it should not be hard. Thanks
NXN
Old 09-10-2008, 10:17 AM   #7
WithChild
Profile:  2006 16' International CCD
Minneapolis , Minnesota
I have a '62 Overlander that has no table. Does anyone know if they originally had something? Any ideas of what would work?
WithChild is offline   Reply With Quote
Old 09-10-2008, 12:19 PM   #8
purman
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
don't now if they did, must have had something... You could put in a post table.. Andy should have them or Vintage Trailer Supply - Vintage travel trailer parts and supplies! has some that flush mount in the floor...
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
'89 Jaguar XJ6 It would look so cool
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-10-2008, 01:56 PM   #9
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Nixon66
You need the other half of the slide hinge mechanism show in Overlander63 pictures. Try and get back to the E Bay seller and see if he has it. If not try a Dealer or someone like COLAW RV PARTS & SALVAGE | WE HAVE YOUR PART!
The table is designed to hinge out of a shallow box enclosure that is part of the shelf under the window. You don't have to have the shelf as originally designed but just an enclosure will be enough to finish off the installation. Once the table is out the slide hinge allows the table to be pulled about 10 ins. closer to the couch. This sliding allows people to get in behind the table with out being contortionist.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Anybody replaced the folding table? Denis4x4 2006 Safari SE 6 11-07-2007 08:15 PM
Plans for Folding Table The Flintstones General Interior Topics 6 01-16-2007 07:23 PM
Lounge Folding Table RestorinanAS Cabinets, Counter Tops & Furnishings 2 02-12-2006 11:49 PM
Folding Table Hinges JOHN L Parts Archive 4 06-16-2004 08:10 PM
Installing folding table Happycampers General Interior Topics 5 03-13-2004 06:31 AM
Forums Directory
