Old 02-23-2015, 08:22 AM   #1
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Need help indentifying wood species
Want to put a wood panel on my fridge to match my cabinets. 1954 or 1955 Flying Cloud. Have been told this is maple but might be birch. Any experts out there?
ID:	232957   Click image for larger version
BambiTex is offline   Reply With Quote
Old 02-23-2015, 09:49 AM   #2
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
The interior of your AS indicates a lot of TLC. Looks great!
I do a little wood working and it appears to be birch. Birch is often used for cabinet making.
Old 02-23-2015, 07:53 PM   #3
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Hey Bambitex,
I had a 1954 Empire (canned ham ) that looked the same. It was birch. It was hard to match the old birch veneer, I think they probably slice it differently these days.
Tim
Beaker63 is offline   Reply With Quote
Old 02-24-2015, 05:52 AM   #4
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Well that's not very encouraging :-)
Old 02-24-2015, 06:00 AM   #5
64airstream's Avatar
1964 22' Safari
1968 26' Overlander
Beaver County , Pennsylvania
BambiTex,
You may want to do an internet search for hardwood lumber dealers in your area or region. Often the big box stores only carry what they can sell by the truckload. We found a place near Toledo (about 4 hrs from us) called Homestead Hardwoods that have a pretty good selection. They sell mostly to the boating community.
Good luck,
Roy and Marie
64airstream is offline   Reply With Quote
Old 02-24-2015, 08:51 AM   #6
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Fortunately Houston is home to two excellent sources:
Houston Hardwoods and Clarks Hardwood Lumber
Old 02-24-2015, 09:28 AM   #7
1963 19' Globetrotter
Marfa , Texas
I have some Clark's Hardwood in my trailer. They have a nice selection, albeit expensive, of veneers. I bet you could find some flame or bird's eye Birch there - or maybe online at a better price. If it appears lighter than your original cabinetry it's nothing that years of sunlight won't fix.
Augustine is offline   Reply With Quote
Old 02-24-2015, 10:16 AM   #8
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
From the photos it looks like rotary cut birch. Practice with scrap of the birch ply and amber or orange shellac to match up the color of the aged varnish. My first guess would be amber but that may not be dark enough.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 02-24-2015, 10:29 AM   #9
2017 19' Flying Cloud
Madison , Wisconsin
Send a message via AIM to jtwind Send a message via MSN to jtwind Send a message via Yahoo to jtwind
Birch Plywood is probably one of the most common hardwood plywoods found in lumber yards and home centers, Would be worth starting there. Usually this is Yellow Birch.
jtwind is offline   Reply With Quote
Old 02-24-2015, 10:57 AM   #10
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Tks!
Old 02-24-2015, 11:19 AM   #11
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
Part of the difficulty matching old with new is the simple aging process - the deep amber that your panels are showing now would have been quite a bit lighter when the trailer was new - you can work to match it but it may take a bit of trial and error.
Might want to consider including a bit of a search for some old cabinetry that you can use.
Good luck,
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 02-24-2015, 11:37 AM   #12
2002 19' Bambi
Lafayette , California
Jay is correct. The amber color is typical for wood like birch with a varnish finish and results from changes both in the surface of the wood and in the varnish. Before finishing your new refrigerator panel, use some pieces of the same plywood for experimentation with a light stain and the varnish you intend to use, working toward the best color match you can achieve.
Tim
Tim A. is offline   Reply With Quote
Old 02-24-2015, 11:55 AM   #13
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
That was my plan. I have a couple different shades that are close. Will test them on scraps until I get a close match. Do you think it is just varnish or stain too?
Old 02-24-2015, 01:47 PM   #14
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I think it is just varnish. Here are a couple photos showing a different piece of the same sheet of birch plywood, unfinished and finished. On the finished piece, I used Minwax Helmsman Spar Urethane with no stain or color additives. The urethane has been on the plywood about three months, and has already yellowed quite a bit from when I first applied it.
If you add any stain to try and match the finish of the existing wood, be aware that some additional yellowing may occur over time based on the varnish you use and take that into account.
Also, all birch plywood is not made alike. Most of what is available at Home Depot and other places has a super thin (less than a millimeter) layer of birch veneer over another type of softwood. This would make any future refinishing almost impossible without sanding down into the softwood layer. I would shop around and see if there is some with a thicker layer of birch veneer. If you can find it, it may be more expensive, but may serve you better in the long run.
ID:	233055   Click image for larger version
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
'69 Overlander cabinetry wood species? liviniseasy Cabinets, Counter Tops & Furnishings 9 05-11-2014 06:57 AM
Replacing fake wood with real wood webspinner General Interior Topics 65 04-03-2013 09:13 PM
To wood or not to wood? warrenivan Classic Motorhomes 20 11-07-2011 07:38 PM
New water heater-- Need wood frame? gparker Water Heaters, Filters & Pumps 0 05-30-2007 07:34 AM
Endangered species list? streamer23 WBCCI Forum 27 02-01-2007 10:16 AM
