Old 08-14-2013, 11:57 AM   #1
1977 Argosy 24
Milltown , Wisconsin
need better table support
I put a 3 sided lounge in the front of our Argosy. The table is supported by on chrome 3" pipe that fits into an aluminum socket on the floor and the bottom of the table. The floor flexes and the pipe moves in the sockets if you put any pressure on the edges of the table. I would be afraid to take it down the road with the table up, the way is moves around. I could pull the belly pan and re enforce the floor with another steel crossmember, but the pipe and socket setup will still move around. Is there any better system out there for a removable table that I could install?
Name:	Booth W:Table.jpg
ventport is offline   Reply With Quote
Old 08-14-2013, 12:01 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy!
Can you add a plate to the pipe to mane a wider base in top of floor? A nice piece of diamond plate with a hole in the center would spread the load. Just weld it on
PM if want to discuss.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-14-2013, 12:09 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
One thing you might try is to take some eye bolts, or eye screws, and attach to the underside of the table on all four corners, and to the floor directly below the table corners. Then, using quarter-inch coated steel cable (low stretch that way) and some turnbuckles (to adjust the tension) run cables from the eyes in the table to the eyes in the floor. With the cables all properly tensioned (but not tight enough to pull out) the table should be very stable. When you're parked, you can remove the cables to get them out of the way and use the table normally.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-14-2013, 01:10 PM   #4
1977 Argosy 24
The table is too tippy with just the single pole to eat off of without spilling your drink, if someone leans on it. There must be something better out there then just the pole and brackets I now have.
Old 08-14-2013, 01:21 PM   #5
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
There is a pneumatic pedestal out there that's perfect for your needs.
Airstream uses them in the new 22(?) and 2014 23FB.
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 08-14-2013, 01:48 PM   #6
1981 31' Excella II
New Market , Alabama
I have seen tables with two post mounts like what you have. Nice dinet. I bet those cushions set you back a piece. It is too late now but before you put down the flooring you could have put some extra wood under the sub floor where the post mounts.
Perry
Old 08-14-2013, 01:59 PM   #7
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
There is a RV TRIPOD TABLE LEG BASE on rv surplus and ebay. I will be using that to move the table around. There was one model that was height adjustable also. Sorry unable to add a link to this but easy enough to google search
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 08-14-2013, 06:34 PM   #8
1977 Argosy 24
What do the rest of you that have a 3 sided booth with nothing to attach the edge of the table to use for a table leg that doesn't wobble?
