Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 04-26-2004, 06:09 AM   #1
Profile:
Mounting Brackets for Folding Table??
Bought a set of metal brackets and wire to build a folding table.
Cant for the life of me figure out where and how to configure the brackets.
There are:
1 pair (AA) wall brackets.
1 pair of (BB) brackets that has an ear that fits into the wall bracket, and
also holds the wire.
1 pair of (CC) brackets that hold the wire.
1 (DD) wire.
An explanation or photo would be greatly appreciated.
Dick
Navigator is offline   Reply With Quote
Old 04-26-2004, 04:44 PM   #2
Profile:
Btt.........................please
Old 04-26-2004, 05:14 PM   #3
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
What bracket?
Can you elaborate on what exactly you're trying to do?
I'd love to help, but have not the foggiest idea what you're asking us.
Uwe
Old 04-26-2004, 08:45 PM   #4
Profile:
UWE, thanks for the reply. There are 2 ways to build a folding table so that it can be converted to a bed / couch. Both styles are found in Airstreams.
1, Center post with floor and table-bottom plates.
2, Brackets and a very heavy inflexible wire hoop.
Now I bought the metal parts for the 2nd option, and fabricated a plywood table top that also serves as the base for a bed, but just cant seem to figure how or where to screw the brackets, so that in the up position I have a table, and in the bottom position, there is a bed platform. Any insight would be sincerely appreciated.
Dick
Old 04-26-2004, 09:32 PM   #5
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 92
While I am familiar with the table bracket you are talking about, I don't know the height to mount it at. I've attached a diagram of it from the Nolans RV catalog...probably not big enough to be of much help though...
We opted for a third option to the two you mentioned, the Perko brackets & collapsible leg, when building in our dinette last year...they worked out very well.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 04-27-2004, 05:21 PM   #6
Profile:
Insideout,
Thanks for the diagram. That is the bracket set that I bought.
The difficulty I'm having is in order for that to work, the "Catch bracket" #42399 needs to be mounted on the wall with the opening facing down! And that does not seem right to me, or am I missing something?
Dick
Old 04-27-2004, 07:49 PM   #7
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Originally Posted by Navigator
Insideout,
Dick
The opening does face down. When putting the table up, you tilt up the far (leg) end of the table and insert the tabs on the table end under the openings in the catch bracket. When the leg end of the table is lowered, the tabs go up inside the bracket and the table is then fastened to the wall.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 04-28-2004, 04:38 AM   #8
Profile:
Smile
Thanks John,
Old 04-28-2004, 08:51 AM   #9
Pahaska's Avatar
Images: 12
A photo
Here is a photo of the brackets laid out in the way they will be installed.
First, put the brackets and the rod on the table end. The tabs point up. Put the table in the down position with the wire agaist the wall. Put the hinges on the rod and screw them to the wall. Next, swing the table up with the end firmly against the wall. Put the top brackets on the tabs and screw them to the wall. Done!
John W. Irwin
Old 04-28-2004, 09:10 AM   #10
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
Confused
Pahaska, I find the photo alittle confusing.
Does'nt the tabbed brackets go towards, (on the table top), the "catch" brackets that will be mounted on the wall?
It appears the the tab brackets are on the opposite side in the photo.......
But I have heard "it is so clear it is hard to see"
Smily
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 04-28-2004, 01:39 PM   #11
nellie the elephant's Avatar
Profile:
I've been looking for these...
"Navigator Bought a set of metal brackets and wire to build a folding table...."
Please let me know where you found these brackets, as I am interested in doing the same thing. Also, how do you configure the "landing" where the table will rest? Do you just create a notch on the lower cabinets? Any info would help. Thanks.
Nellie
nellie the elephant is offline   Reply With Quote
Old 04-28-2004, 02:00 PM   #12
InsideOut's Avatar
1956 22' Safari
Images: 92
If you can't find it anywhere else...it's available online @ Nolan's RV here in Denver.
Good Luck!
Shari
Old 04-28-2004, 02:03 PM   #13
Pahaska's Avatar
Images: 12
Smily
The tabs are laying flat on the truck bed cover, pointing away from the camera. The table top would be vertical with the bottom toward the camera.
oakhill just came by a few minutes ago to pick up the hardware and I demonstrated to him how it works and how to install it.
John W. Irwin
Old 04-16-2007, 07:30 PM   #14
MontanaArgy's Avatar
Profile:  1976 Argosy 20
Helena , Montana
Brackets wanted! Help
I've been looking for a set of the above dinette table brackets, and they are apparently discontinued. I have the wire and the wall brackets, still need the two pairs of brackets which go on the table. Any body have or know where to find them? I tried Nolans as mentioned above. They were called "Lif-table" brackets. Used would be great! I will go with the Perko if I can't find these. Thanks
MontanaArgy is offline   Reply With Quote
Pingbacks are On
50's Table?? GT1963 Cabinets, Counter Tops & Furnishings 17 09-03-2004 03:01 PM
Installing folding table Happycampers General Interior Topics 5 03-13-2004 06:31 AM
wall table farmerjim General Motorhome Topics 7 12-12-2003 07:29 AM
Dinning table ROBERT MOE General Interior Topics 0 02-24-2003 03:30 PM
LP Tank Mounting bracket kzener40 LP Gas, Piping, Tanks & Regulators 1 08-21-2002 04:40 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
