I'm restoring our 1970 Overlander and all of the tambour doors from the overhead lockers are missing. The guides are still there, and the brackets for the rods, but everything else is gone.
I know I can buy the tambour from InlandRV but apparently they don't have the spring loaded rods.
Any suggestions on where I can find them or how to work around that would be appreciated!
My 70 Safari is the same way, the tracks and brackets are there but nothing else. I haven't tried it yet but I plan to use the spring loaded rods from vinyl window shades. I'll remove the vinyl from the rod and mount the tambour. It should work if there's enough spring tension to roll the tambour.
