Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 03-18-2004, 07:03 PM   #1
Profile:  1983 34' Limited
Las Vegas , Nevada
Send a message via MSN to dmadam
Missing cabinet door
Hi Folks
Just purchased a 1983 Limited 34' and the hall cabinet shown in the photo is missing. If anyone could help me find one I would appreciate.
The unit is great and does not need much but I am going to update it with new carpet, curtains, counter tops ect.
Thanks all
dmadam is offline   Reply With Quote
Old 03-18-2004, 07:08 PM   #2
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , West Planet Houston, Texas
Images: 231
Welcome to the Forum!!
Isn't the interior workmanship great??
You will find a HUGE wealth of information here in the Forums.
There is a good representation of all Airstream products - we all try to share information.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 03-18-2004, 07:18 PM   #3
Profile:
That should be relatively easy to make. The effort would be to match the grain and color of the adjacent wood.
Dick
Navigator is offline   Reply With Quote
Old 03-18-2004, 09:45 PM   #4
Las Vegas , Nevada
missing cabinet door
Thanks for the posts
I have thought of making it but I think the color match would be tough. The other think is I dont know if it was a solid door or a frame with an inset like the one below it.
David
Old 03-19-2004, 09:07 AM   #5
87MH's Avatar
Images: 231
What do you intend the cabinet space to be?
From the 110 volt receptical in the cabinet space, it looks as if the original use was a microwave, oven, or possibly an icemaker?
If you need to add an appliance (kitchen, stereo, or TV), a "built in" look would be easy to accomplish.
I have found that matching the patina of the wood just takes a bit of experimentation. Start with a good oak board, and add just a bit of stain at a time, and finish with a good "Tung" oil.
How about some additional interior and exterior photos?
Dennis
WBCCI # 1113
AirForums #1737
Old 03-19-2004, 09:16 AM   #6
Edie's Avatar
Profile:  Dallas , Texas
Looking at the photo, I think the door is needed for the space above the area with the outlet.
Try calling some of the Airstream graveyards. I'd start with Bob's RV Salvage (386-454-5733) or Colaw RV Salvage (417-548-2125). They should be able to ship the door if they have it.
Edie
Edie is offline   Reply With Quote
Old 03-19-2004, 10:57 AM   #7
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Judging by the hinges and holes for hinges plus the magnetic stop on the top, I believe this opening had two vertical doors over the entire height of the opening. Just my observations. Maybe the doors were removed to take out the original microwave because the outlet was faulty. I would bet the PO has them around somewhere.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 03-19-2004, 12:46 PM   #8
Edie's Avatar
Lightbulb
Gottcha! Now I see it. I was guessing the lower area was meant to be open based on the fact that the inside is finished with the same wood grain material as the outside of the cabinet.
Edie
