Old 09-11-2011, 07:23 AM   #1
2006 19' Safari SE
chandler , Arizona
Mirror above vanity fall off
I have a 19ft bambi special edition 2006 and the mirror keeps falling off of the cabinet above the sink/vanity it is only held up by some kind of silicone and double sided tape, I applied liqud nails on it yesterday and don't know if this will even work, anybody have any ideas on how I can better secure the mirror to the cabinet door?
popeye1 is offline   Reply With Quote
Old 09-11-2011, 07:44 AM   #2
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
There is a 3M product (I don't have the specific code name for it), available at WalMart that is designed specifically for your type of application.
It comes precut in strips. It's expensive, but will do the job well.
Good luck!
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 09-12-2011, 04:23 AM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
PPL also makes a mirror adhesive (caulk) that you can get at Lowe's...
Old 09-12-2011, 09:10 PM   #4
idmtman's Avatar
Worley , Idaho
I had a similar issue this past spring. I noticed there was a large amount of some kind of caulking behind the mirror but it is also held by mirror clips. I tried construction adhesive with minimal results, though the metal clips hold everything tight, but I would really like to find the "correct" product.
After an internet search, I see that Liquid Nails makes a mirror adhesive, LN-930, which comes in 10 ounce tubes for about $5 at Home Depot. Palmer Mirro-Mastic sells for $7 at Amazon.com. I think I will buy one of these and re-install. I'll feel better knowing it is installed as per the original. Thanks for the help.
Idmtman
2006 Safari 28' SE (Sylvia)
75th Anniversary Edition
2010 Toyota Tundra 4x4
TAC: ID-1
idmtman is offline   Reply With Quote
Old 09-12-2011, 09:37 PM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Pardon my fat finger error above - it's PL not ppl. The product is made by Loctite....
Loctite PL Mirror Mastic Construction Adhesive at Menards
Does your under Sofa storage drawer fall out on the floor?? ROBERT CROSS Cabinets, Counter Tops & Furnishings 4 04-11-2016 03:02 PM
SoCal : CA Streamers Fall 2011 Rally - Kernville 5 BamCamper Forum Rallies & Meet Ups 45 11-07-2011 02:17 PM
Fall Fiesta in Northern Illinois Tom Nugler Forum Rallies & Meet Ups 28 10-10-2011 09:01 AM
