Old 11-24-2018, 04:12 PM   #1
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
Medicine cabinet door wonít stay open
Our International has a ceiling attached medicine cabinet (1st picture, opened) with an external pivot hinge (2nd picture) on both ends for the cabinet door which has a mirror.
It is annoying that the medicine cabinet door cannot be made to stay open, as is the case for the galley storage bins in a Flying Cloud for example (which have a different hinge mechanism).
Has anyone “upgraded” their medicine cabinet and its unique pivot hinge with some kind of mechanism to keep it open? I have wrapped a cord around the door to keep it open as temporary solution—not very pretty.
If you have found a solution it would be much appreciated!
ID:	328477   Click image for larger version
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap,
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 11-24-2018, 04:58 PM   #2
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
https://www.rtacabinetstore.com/RTA-...es-soft-close/
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 11-24-2018, 05:01 PM   #3
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
ID:	328480Attachment 1Click image for larger version
Hereís the fix.
sheriff1 is offline   Reply With Quote
Old 11-24-2018, 05:06 PM   #4
AlinCal's Avatar
1991 25' Excella
https://www.cabinetparts.com/c/hinge...and-flap-stays
Will Rogers
Alan
Old 11-24-2018, 05:40 PM   #5
Senior Member
sheriff1's Avatar
Sparks , Nevada
Same fix works over fridgeClick image for larger version
Old 11-24-2018, 05:41 PM   #6
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Yep easy to do and works great.
Old 11-24-2018, 08:54 PM   #7
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
Single strut works great - keeps mirror up and out of the way. Only one needed and easy to install. There a a few threads on this on the forums.
az-streamer is offline   Reply With Quote
Old 11-25-2018, 05:50 AM   #8
D44
D44's Avatar
2017 25' Flying Cloud
Lawn Guyland , New York
Originally Posted by az-streamer View Post
Attachment 328490
Can you link to that strut so we can find it - thanks!
Walt
WBCCI - 29375
D44 is offline   Reply With Quote
Old 11-25-2018, 06:10 AM   #9
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Looks like a great fix to an annoying problem.
Thanks for sharing!
Old 11-25-2018, 06:13 AM   #10
2017 27' Flying Cloud
Fort Worth , Texas
Correct me if I am wrong, but when I looked at the strut solution, it is made to get the cabinet door to 99 degrees from the base cabinet. The problem is that the base cabinet is tilted so that opening the cabinet door to 99 degrees does not get it to horizontal with the floor. If you are tall, it puts the open door right in the middle of my forehead.
billrector is offline   Reply With Quote
Old 11-25-2018, 06:21 AM   #11
Long Island , New York
The new search function in the blue box above works great! Here are the results for "medicine cabinet door strut" --
https://www.google.com/search?q=medi...=airforums.com
. . . with many products linked in those threads, like this one:
https://www.amazon.com/Lift-Supports...p_4%3AStabilus
Good luck,
Peter
PS -- billrector, by choosing the correct strut length, and mounting it in a good location, you should be able to get the door into any position you want, when it is open.
Old 11-25-2018, 09:36 AM   #12
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
Has anyone converted that cabinet to a pair of sliding, mirrored, doors? If so how did you do it?
daleyocum is offline   Reply With Quote
Old 11-25-2018, 09:48 AM   #13
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Also consider...cheep plastic will turn to dust. 😂👎
ID:	328531   Click image for larger version
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 11-25-2018, 12:00 PM   #14
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
This solution from Sugatsune works for us:
https://www.amazon.com/gp/product/B00IKFSX88
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Flying Cloud medicine cabinet door zigz On The Road... 26 08-20-2019 03:53 PM
Windows won't stay open GLovedahl Windows, Doors, Locks & Vents 12 07-22-2018 08:45 AM
Plastic medicine cabinet latches willbrackman General Interior Topics 6 05-08-2017 08:07 AM
Heavy mirror above medicine cabinet titleists Cabinets, Counter Tops & Furnishings 12 05-24-2013 10:26 AM
Medicine cabinet door won't stay closed jordandvm Cabinets, Counter Tops & Furnishings 10 10-03-2004 08:24 AM
