Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 02-25-2004, 01:08 PM   #1
fitzjo1
Profile:  1968 26' Overlander
West Columbia , South Carolina
Looking for 5mm or 3/16" plywood
I want to replace a plywood panel in my 68. The aluminum channel that attaches the edge of the panel to the wall is sized for 3/16" plywood (which is the thickness of the original stuff). Unfortunately, I'm having a tough time finding plywood of this thickness in any species, let alone walnut.
Any suggestions?
Jon in SC
fitzjo1 is offline   Reply With Quote
Old 02-25-2004, 02:05 PM   #2
Tripp
Profile:
Images: 55
I'd use 1/4" ply and "back bevel" the bottom with either a hand plane or belt sander where it sits in the channel. Once installed, you won't notice it.
Tripp
Tripp is offline   Reply With Quote
Old 02-25-2004, 02:31 PM   #3
Royce
Royce's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
I use Boulter Plywood corp for the marine grade plywood used in the canoes I build. They have always been good to deal with and have a great selection of material.
Link.Boulter Plywood
Royce (K0RKK) and Karen
AIR# 3913
Royce is online now   Reply With Quote
Old 03-10-2004, 08:12 PM   #4
Tarheel
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
3mm and 5mm are quite common in the marine world, but you won't find it at home depot. It took me a while to find a source of 1/16" aircraft grade plywood but its out there.
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 03-10-2004, 08:22 PM   #5
Navigator
Profile:
I just trashed some wall paneling from my rec room, and it measured 5/32
Dick
Navigator is offline   Reply With Quote
Old 03-10-2004, 08:52 PM   #6
Tarheel
Tarheel's Avatar
Images: 21
I bet doorskin 3' x 7' panels measures about that and boy is it inexpensive.
WBCCI # 3485
Region 3 1stVP
Old 03-10-2004, 08:54 PM   #7
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
You can use the 1/4 and run a router with a flat bit down the edges.
You can also use 1/8 and then use 1/16 walnut veneer. Depends on if both sides of the panel are visible, because teh veneer would only fit single sided.
Or, you can use 1/8in walnut with thin spacers to make up the difference inside the channel.
Uwe
