Old 08-29-2010, 12:42 PM   #1
1988 32' Excella
Chapin , South Carolina
locking mech. for drawer under sofa/bed
Has any one got a better idea for locking the drawer under the sofa in a 1988 excella? You have to lift up the sofa on mine to lock it in place while traveling. THANKS
Shoulder is offline   Reply With Quote
Old 08-29-2010, 03:57 PM   #2
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant , South Carolina
Hey Shoulder,
Welcome to the forums.
Have you tried traveling without latching it? We have been many thousands of miles in our '88 and have never found the drawer open when we got anywhere. I've never latched it. Mine doesn't open that easy normally and maybe that helps.
Aside of that, your options for keeping it locked externally are to put some sort of latch on the outside that would have to connect to the floor and would always be kicked or bumped while sitting at the gaucho/table.
Good luck,
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 08-29-2010, 04:50 PM   #3
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
drawer
We have the same kind of mechanism and situation. It always slides out as we are motivating down the road.
We have seen some of them changed to the outside front of the couch. Same mechanism but moved. They mount it so that it is under the skirt (material) on the front of the couch. A small hole the same diameter as the locking shaft is drilled into the floor to lock it down. Then you do not have to lift the couch to engage it.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 08-29-2010, 04:54 PM   #4
2007 25' Safari FB SE
Eureka Springs , Arkansas
Check out Lee Valley #00K12.01 travel latch.
RV suppliers also have similar latches.
I added a drawer where the oven was and needed something like this.
In the end, our daughter had extra child proof drawer stops, so I used that. It works.
triplenet is offline   Reply With Quote
Old 08-31-2010, 06:27 PM   #5
1988 32' Excella
Drawer under sofa.
Thanks for the replys-think I will take Lou's suggestion and move the latching mech. on the outside nof the drawer.
Sofa bed, dinette/bed, swivel chairs and fold out table Don Landis Argosy Motorhomes 9 09-07-2011 07:56 PM
Sofa bed, dinette/bed, swivel chairs and fold out table Don Landis General Interior Topics 0 04-21-2009 02:18 AM
Need Bed Drawer shermantic All Argosy Trailers 12 01-31-2009 07:41 AM
