Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 02-04-2006, 03:01 PM   #1
Airstreamin and luvin it
Commercial Vendor
Devoman's Avatar
Profile:  2005 25' Safari
Northwest Panhandle , The Sunshine State/WBCCI 6637
Light Plywood
I am wondering if anyone knows where I could purchase this plywood that Airstream uses?What is this stuff actually called?
It is the wood they made the cabinets and such for mine.
Thanks.
Blue Numbers and Signs
E-mail me for quotes.
Devoman is offline   Reply With Quote
Old 02-04-2006, 03:07 PM   #2
Chaplain Kent's Avatar
Profile:  1994 30' Excella
Wauwatosa , Wisconsin
Have you tried contacting the factory and asking what it is called and where you can purchase it?
Chaplain Kent
1994 30' Excella 1000, Chummy III- E350 Ford Super Duty
http://travelswithchummy.blogspot.com/
Chaplain Kent is offline   Reply With Quote
Old 02-04-2006, 03:22 PM   #3
Commercial Vendor
Devoman's Avatar
Not yet
No not yet.I thought I could get a faster answer through here.
Old 02-04-2006, 03:24 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
I think 'Pahaska' John Irwin has mentioned the name before... Might try PM'ing him.
Old 02-04-2006, 04:03 PM   #5
Profile:  , Minnesota
Images: 59
Try asking for Poplar plywood. It comes with various veneers. I may also be called furniture panel plywood, or even 'Lightweight' plywood.
Poplar is a softwood that makes a light but sturdy core. I'm pretty sure you can get it (in limited sizes and thickness) at HD.
Old 02-04-2006, 04:12 PM   #6
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Mine has 1/4" 5MM ply for the cabinet bottoms it is oak and can be purchased anywhere. Yours is probably Ash as thats what they have been using for the last several years. Match the stain and you will be in business.
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 02-04-2006, 04:36 PM   #7
Craftsman
Guest
Profile:
Posts: n/a
Take a look at www.winwood-products.com. This in Poplar ply thats about 40% lighter than regular ply.
Old 02-04-2006, 04:56 PM   #8
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
Veneer core plywood likly. Being were you live it should be easy to get the stuff in a wide variety of face veneer, ie ash, teak, ect. Google it.
SOFI Member
Over59 is offline   Reply With Quote
Old 02-04-2006, 05:13 PM   #9
SmokelessJoe's Avatar
Profile:  1976 Argosy 24
TORONTO and Southwestern , Ontario
Devoman:
This is probably what you are looking for. Balsa Plywood.
try www.noahsmarine.com
Sergei
SmokelessJoe is offline   Reply With Quote
Old 02-04-2006, 05:25 PM   #10
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Found it here...
there was an article in Dwell magazine about a house that used this material extensively through their house. Per the article, theatre houses use it to make props, as it's lighter than normal ply. Here's the link to my local distributer.
http://www.comptonlbr.com/ look under "building materials" for lite-ply. They have a hyperlink that lists it's weights for various thicknesses. It's also bendible in thinner thicknesses.
Marc
Old 02-04-2006, 05:29 PM   #11
TomW's Avatar
Profile:  1967 26' Overlander
Huntsville , Alabama
Originally Posted by Over59
Veneer core plywood likly ...
That's what mine is in my vintage Airstream. The kicker is finding it in a thickness that will match any Airstream-provided extrusions you may be using.
FWIW, my cherry veneer plywood is 3/16" thick.
Tom
Old 08-22-2006, 10:13 PM   #12
Geezer
Sapulpa , Oklahoma
I am a woodworker and have read and studied the available plywood. The strongest and perhaps the easiest to work with is Baltic birch. It is stronger than the plywood they use in the Argosy and will take stain beautifully. It costs a little more but it is worth it. The stuff in my Argosy is quite cheap and appears to be luan. Lu-an splinters and has a very thin veneer. Woodcraft usually stocks 1/4" Baltic birch and I can get it at my local small town lumber yard. Try it you will like it.
LRPorter is offline   Reply With Quote
Old 08-22-2006, 11:09 PM   #13
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Thanks.
I tried to find the lightest plywood in 1/4 in when shopping for materials for the 63 Overlander. As it turns out, the weight savings at this thickness are minimal. You might save 20-30lbs on the entire interior paneling.
The difference between oak, maple and birch in the 1/4in size is negligable.
Italian Poplar light ply is definitely the lightest variety that still has a nice look to it.
Uwe
www.area63productions.com
'66 tail light bulbs Derk Lights - Interior & Exterior 8 01-28-2006 10:43 AM
Pilot light in Frig niftypkg Refrigerators 9 04-10-2005 01:04 PM
Hitch light plugs ALANSD Brakes & Brake Controllers 4 10-12-2002 10:04 PM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 04:37 AM
Clearance light wiring Bob Evans Lights - Interior & Exterior 6 05-27-2002 12:03 PM
