Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 02-09-2005, 10:56 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Laminate Gurus
I decided to make a new kitchen counter top. I cut the ply to the size of the counter and laminated the whole thing.
Now I am not sure if I can cut the sink and stove openings with my jig saw w/o damaging the laminate.
Can I drill holes for the faucet?
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 02-09-2005, 11:16 PM   #2
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Sure you can, use a fine tooth blade and go slowly. For the holes, use a pan bit and go slowly here too. You'll be fine.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is offline   Reply With Quote
Old 02-09-2005, 11:27 PM   #3
Stefrobrts's Avatar
Profile:  1968 17' Caravel
. , Washington
What's a pan bit? I'm going to be doing the same job in the next month or so.
Stephanie
Old 02-10-2005, 04:22 AM   #4
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Tim,
Yes but make sure you use a SHARP bit, I prefer to use the Forstner style bits, as far as cutting the sink hole, cut from the back side and it will minimize chip out, of the laminate. Also just take it slow and easy and let the saw do the work. A sharp new blade is in order of the saw too.
Aaron
WBCCI #2449 AIR #2495
Old 02-10-2005, 09:41 AM   #5
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
You can buy an inexpensive hole saw and make the holes for the faucets. If you want to cut from the top put down masking tape and layout the hole onto the tape. Even if you do get some chipping you will have a minumum of .375" of lip to cover it. Just be certain to make a template of your sink opening to use for making your cut. Its not as bad as it seems.
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 02-10-2005, 02:21 PM   #6
GA Airstreamer Air_005
Profile:  North , Georgia
Send a message via Yahoo to ALANSD
I lay out the blue masking tape, draw my lines on it, and cut through it. That way you don't chip the laminate at all. I use the laminate blade so it only cuts on the downstroke.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 02-11-2005, 12:45 AM   #7
Safari Tim's Avatar
Images: 35
Just to let you all know, I tried all these ideas and it worked great.
I marked out the stove and sink cut outs using the original counter as a template.
I used a new 1" paddle bit and drilled out the corners and the faucet mounting holes.
Then I put the blue tape down and marked the lines for the sink and stove on the tape and used a new fine toothed laminate blade. I went fairly slowly.
Result was a great cut and no chips in the laminate.
Thanks for all the help! It turned out more worry than work.
-Tim
Old 02-11-2005, 06:23 AM   #8
great! I was amazed how easy this was with a few simple tips. My kitchen and bathroom now look great .
My Music Site:
Old 02-11-2005, 07:41 AM   #9
Tarheel's Avatar
Images: 21
Glad you had sucess, its a great feeling to plan a project and see it all come together.
WBCCI # 3485
Region 3 1stVP
Laminate hints & tips? TomW Cabinets, Counter Tops & Furnishings 7 07-20-2004 01:10 PM
2003 International AS Pahaska 2003 International 147 05-28-2004 10:48 AM
The New Floor is in the 345! swebster Repairing/Replacing Floor &/or Frame 9 04-18-2004 07:23 PM
year wood veneer changed to laminate? thx yukonsilver Interior Restoration Forum 4 04-18-2004 06:31 PM
Counter laminate Forrest Cabinets, Counter Tops & Furnishings 1 07-06-2002 07:06 AM
