We have a 79 Excella and from what I think, the wood is a plastic laminate done to look like Koa, does that sound right? I need to replace a bunch of the tambor and haven't found any made to resemble Koa so if that is truly what I have are there any suggestions on where to find a match?
Dan
1979 31' Excella 500 Under Renovation, As yet to be towed!
Lots of people have problems with those. Many take them all out and replace. Some post the usable remainer on this site and VAC site as well as ebay. That might be your cheapest source if you want to keep the original look. Otherwise some people remount them with new backing, if that is your problem.
Dan, I doubt Airstream used Koa but you never know. If you want them made from Koa,it doesn't seem to difficult to do with basic woodworking tools They're basically just strips of wood glued to a backing with a rabbet on the edges. Rout the rabbet on the edges, rip to width, sand the pieces, lay them out and glue to the backing. Take your measurments from the old tambors and you have them in any exotic wood you want.
I would agree with Craftsman -- it doesn't make sense that Airstream would ever use Koa. Here's but a small sample of search returns on tambour -- the ones that seem more useful to your question at least.
... interestingly the new 75th limited model has real walnut veneers on the cabinets … and it looks amost as real as the simulated 1979 trim cheers, 2air’
2air':
You're right. I've looked very long and hard at the wood in the Winnick 75th Anniversay Edition Bambi's, and my initial reaction was disappointment that the production models used laminate instead of real wood. If, in fact, it is real wood, then I'm amazed how the factory -- perhaps through the miracle of modern plastic finishes -- can make real wood look exactly like a laminate. Somehow, they've achieved a uniform dull sheen that screams "LAMINATE" instead of real wood with nature's inherent flaws. I'm still not convinced its real wood in there. Is it?
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Charter Associate Member FCU
Airstream Life "Old Aluminum Adventures"
Here is a pic of the wood i have, I don't think it walnut as I a pretty familiar with it, cherry, oak , etc. In one of the documents I have it referenced Koa and I know there is a Hawaiian wood by that name hence my assumption.rickandsandi, I can't find much on the website you reference so I'll just give them a call.Thanks all,Dan
Dano57,
I have that same stuff in my 1980 Excella...I think it is wormy oak other than that it ain't wood it is laminate, so you can do about anything you want with it. My 75 has the dark "teak" interior, I have found a close match in a laminate from WilsonArt that I am going to use for some repairs. The 80 Excella is getting a full custom of interior, just not sure what it is going to be. I am also considering a mid or rear entry
Aaron
WBCCI #2449 AIR #2495
Yea, I know it's plastic and for that I am somewhat disapointed. I would have thought that something as prestigious as an Airstream would be better outfitted. From my sig you can tell we haven't towed it yet and are just trying to get things functional, but, over the coming years I want to completely rebuild the interior. I am fair at wood work and think I can do a better job than what is in there but that is years in the future. Right now I would settle for replacing the tambor with something close.
Dan
