Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 09-08-2009, 07:25 PM   #1
billiards's Avatar
Profile:  2005 25' Safari
rochester , Minnesota
kitchen draws coming apart
looked at the forum threads...i must be the only one with the problem....the front face of the pull out draws are coming loose from the side frames....glued, guess i will install a cross pin and reglue...anyone else with ideas ...?
billiards is offline   Reply With Quote
Old 09-08-2009, 09:06 PM   #2
Isadora's Avatar
Profile:  1976 Argosy 24
Joplin , Missouri
Well, Norm Abrams on This Old House uses Gorilla Glue. I think I would go with what the expert does.
Jim and Sandy
"To know is nothing at all. To imagine, is everything." --Albert Einstein
Isadora is offline   Reply With Quote
Old 09-08-2009, 09:13 PM   #3
Cantrell's Avatar
Profile:  1988 34' Limited
Mt. Pleasant , South Carolina
A picture would be helpful.
Ours are basically a box with no lid--the face frame is attached to the front of the box. If that is the case then a couple screws through the box into the face (pre drill and use screws short enough to get into the drawer front but not go all the way through, obviously).
If the face also acts as the front of the drawer which is what is sounds like you have, maybe you could get some small 90 degree metal (like 1") brackets and secure the frame to the face that way.
Good luck.
Cantrell is online now   Reply With Quote
my FF moulding is coming....! SilverToy Roof Vents, Skylights & Fans 2 01-09-2007 07:26 AM
The welder is coming, the welder is coming... Safari Tim General Interior Topics 13 09-01-2006 11:00 AM
Broadband is coming! Pahaska Off Topic Forum 1 12-18-2005 03:50 PM
The Airstreams are Coming!! The Airstreams are Coming!! j54mark Airstream "In the News" 7 07-07-2005 08:06 AM
