I really like what you did for your backsplash. I'd like to do something similar. do you know where I can get that material? Is it attached with rivets, screws or adhesive?
South Jersey R.V. got it for me. It was attached using special washers and screws. The quilted stainless steel is a little expensive. $300-$400 for a 4 by 8 sheet? You may find some cheaper material.
That certainly is very nice. A little pricey and elaborate for me.
I was looking for some ideas to replace the usual formica backsplashes like those on prefabed counters that only go up a couple of inches against the wall.
Our '64 has a 2" rubber base that's riveted in place. The color matches the countertops and is original. You could use either 2-1/2" or 4", it comes in many colors and can be bought by the foot very economically.
I used the thin aluminum riveted in place behind the 4 burner stove, and 3/4" aluminum angle over the length of the counter top.
1972 27' Overlander 72 Overlander Jack Pad--- A notebook used by Jack Nicholson in the Shining to keep track of how much work he had done on his Airstream. "All work and no polishing makes Jack's Airstream a dull trailer"
This sounds interesting but I am quite sure I undstand what it is or where to look for it.
It's a rubber backsplash?
You can find it at Home Depot or any flooring store. It is usually either rubber or vinyl, it's the wall base found in most commercial office space, same stuff...different application.
Oh, now I get it. I know exactly what your talking about now.
Thanks for the tip. I'm going to look into it further.
What about the white split (can be folded and is usually used at a 90 degree angle) stuff you can just peel and stick that is usually sold for bathroom tub and sink caulking replacement?
__________________ 1974 28' Argosy (Hey, Airstreams are just Argosy's that haven't been painted yet .. ) 1999 Ford F250 Lariat SD Extended Cab with 7.3L Power Stroke Diesel
Reason: missed important piece of info
This is what I had installed. It's stainless steel.
Very nice!
