Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 08-24-2006, 12:29 PM   #1
j_c_c's Avatar
Profile:  1969 31' Sovereign
Los Angeles , California
Is this an original couch(es) layout??
Looking to buy this airstream, our first!, but want to know if this is an original config for a 69 sovereign - two couches up front in "L" shape....? One is a slider bed, the other not a slider?
Needs work of course, but don't want to start with someone's "custom" job, only want if it is an original layout.....will restore fully someday.....just haven't seen this config before....
Thanks!!!
- jc
ID:	25148   Click image for larger version
j_c_c is offline   Reply With Quote
Old 08-24-2006, 02:02 PM   #2
47WeeWind's Avatar
Profile:  1948 16' Wee Wind
1964 19' Globetrotter
Denver , Colorado
Images: 13
1969 31' Sovereign floor plans
Hi JC:
If the 1969 Sovereign is a twin bed model, then the two front "L" shaped sofas are original, as seen in the floor plans below. If it is a double bed model, which had less sleeping and more storage space, then the "L" sofas are not original and someone has removed the front street side credenza and replaced it with a gaucho (pull-out sofa). Hope this helps.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Charter Associate Member FCU
Airstream Life "Old Aluminum Adventures"
47WeeWind is offline   Reply With Quote
Old 08-24-2006, 02:31 PM   #3
sovereignrwe's Avatar
Profile:  1972 31' Sovereign
Oakdale , Minnesota
Love our '72 "L"
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 08-24-2006, 03:10 PM   #4
Round on both ends
SafeHarbor's Avatar
Profile:  1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Boy, nothing like neatening things up for the buyer.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 08-24-2006, 03:24 PM   #5
GA Airstreamer Air_005
Profile:  North , Georgia
Send a message via Yahoo to ALANSD
The 'L' is a desirable model, you will find that it can be very accomodating. Good luck with your purchase. Make sure you check other threads here to see what to be aware of when buying. Buyers remorse is possible if you don't know what you are getting into.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 08-24-2006, 03:25 PM   #6
j_c_c's Avatar
Interesting......
I wonder if they moved the gouchu from under the front window to the side, then built the little couch and installed the table holder next to the door....
Unfortunately the current owner doesn't know any of the history....maybe I would use the chance to build a custom dinette or something unique...
Side question - where is a good place on the forums to post photos and ask "Is this "worth" $6000"?
(The rest of it looks pretty good and stock)
Thanks!!
- jc
Old 08-24-2006, 08:38 PM   #7
Oakdale , Minnesota
I love the "L" cause I'm 6'2" and the "L" couch offers a longer bed. I believe, the "L" couch was an option on the international (best) package. I can't remember if any part of the VIN number tells you about the couch. You may want to search the forum for that.
Mark
Old 08-24-2006, 10:58 PM   #8
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Thanks!!
- jc
Start a new thread "Is it worth $6000?", post your pictures (as many as you want/have) in the thread and you'll get a response. Location-wise, try the '69 Sovereign forum...
Another idea is to utilize the members "Volunteer Inspector" services.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 08-25-2006, 04:10 PM   #9
Oakdale , Minnesota
At $6000 this should be a trailer that is used regularly and has some things that don't work. At that price, the floor could have some areas of soft floor around the door or around the toilet, but not significant. The trailer should not have leaks.
Always remember that when buying a vintage trailer, you are buying one because you expect to work on the trailer and you understand that the same trailer new off of the lot would cost you $50,000 (for your sized trailer) more. That gives you a lot of spending room for repairs.
I agree with InsideOut's suggestions.
Mark
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 04:51 PM
Original LOOKING interior lights for vintage trailers flamingo-kid1 General Interior Topics 0 04-18-2004 09:04 PM
Roof Vent Original? pepper48 Roof Vents, Skylights & Fans 6 11-09-2002 06:44 AM
Regarding original water tank clean out - thank you! 60stradewind Fresh Water Systems 0 08-22-2002 01:00 AM
New tongue layout FrankR Cleaning, Stripping & Polishing 0 03-07-2002 09:51 PM
