Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 12-15-2006, 09:44 PM   #1
Profile:  Lenoir City , Tennessee
Angry interior demolition and cabinet removal
Hello, I'm starting a complete interior demolition. This includes removing cabinets, beds, bath, closests and everything else in between. I'm noticing that the closets and and frames are secured to the floor with rusted flat head screws. What makes matters worse is that the screws are completely rusted and are impossible to unscrew even by hand. This puts me in a delima because I cannot remove the furniture (e.g., the bed frame) without taking my sawzall and cutting it loose. Does anyone have a suggestion on how I might demo the interior in a gentler fashion. I wish to keep as much of the original cabinetry for refinish or to use as templates. Thanks!
beaker is offline   Reply With Quote
Old 12-15-2006, 09:59 PM   #2
SmokelessJoe's Avatar
Profile:  1976 Argosy 24
TORONTO and Southwestern , Ontario
why not use a chisel to gently cut through the rusted screws?
Sergei
SmokelessJoe is offline   Reply With Quote
Old 12-15-2006, 10:02 PM   #3
GA Airstreamer Air_005
Profile:  North , Georgia
Send a message via Yahoo to ALANSD
can you grab them with vise grips? Maybe soak over night with PB Blaster first.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 12-15-2006, 10:03 PM   #4
guy99's Avatar
Profile:  Dunsmuir , California
Images: 16
Welcome to the Forums. You might want to tell us the model and year of your trailer in case someone has specific experience with your issue.
Have you tried an impact driver or hammer drill on those screws?
Are the screws straight slot or phillips? If phillips, I have had some luck with a screw extractor tool designed for this purpose.
Do you have room to grind down the heads of the screws, remove the frames, and then take the screws out with vice grips (this is what I had to do with a deck we demo'd this summer.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 12-15-2006, 10:03 PM   #5
or drill them out?
Old 12-16-2006, 12:36 AM   #6
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Try the above suggestions regarding chisels, gringing head off, vice-grips, etc. It has been my experience that a left handed drill bit works about the best if you have to drill them out. Extractors work many times, but are less effective IMO.
First center punch the bolt, then drill a pilot hole using a bit 1 or 2 sizes smaller than the left handed bit. Then use the left-hand drill bit to remove bolt, applying firm pressure. The bit should grab the bolt, removing it. The heat from the drilling proccess seems to work to loosen them prior to extraction. Some penetrating oil applied a few minutes prior won't hurt either. If the bolt won't come out with the first attempt, use the next larger bit and repeat. For this reason you don't want to start out with the largest bit that fits the bolt.
Left hand bits are available from Snap-on Tools, and, I'm sure from other vendors.
Dave
Fyrzowt is offline   Reply With Quote
Old 12-16-2006, 07:06 AM   #7
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
I also use a Dremel tool with a cutting disc in it, it allows you to get right on top of the screw and gives you better control. FWIW most of mine were installed with Phillips head screws, so a shot of Kroil and a hand held impact driver did the trick on most of them.
Aaron
WBCCI #2449 AIR #2495
Old 12-16-2006, 07:10 AM   #8
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
I cut mine with a zip wheel it is 4" cutting wheel, same idea as the Dremel but faster.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 12-16-2006, 09:06 AM   #9
Sugarfoot's Avatar
Profile:  1960 24' Tradewind
1956 30' Sovereign of the Road
Southeastern Area , Tennessee
Hi beaker, and fellow Tennessean. Just curious, what year and size Airstream are you working on? Sounds like you've got a major project going there.
TRAVELING WITH ELVIS
LIFE WITH A 1956 SOVEREIGN OF THE ROAD
• • • Aluminocentricity • • •
WBCCI# 14674, Washington DC Unit
Sugarfoot is offline   Reply With Quote
Old 01-01-2007, 08:21 AM   #10
jpeterman's Avatar
Profile:  1972 27' Overlander
Graham , North Carolina
Left handed drill bits
I have had good results with left handed drill bits. They seem to heat the screw and it will screw itself out befor you finish drilling.
Good luck
jpeterman is offline   Reply With Quote
Old 01-01-2007, 09:19 AM   #11
Profile:  1965 26' Overlander
gravel switch , Kentucky
am working on a 65 overlander and had similar problems. bedframes were secured with slotted screws which were all rusted to varing degrees. used a very long screwdriver to which i clamped a vise grim on the shaft. padded the top of the screwdriver and used my shoulder to apply down pressure and was able to loosen some of them that way. some just twisted off. on all the others, i used a hammer driven impact screwdriver. once the heads of the screws cleared the top of the frame i just applied a vise grip and removed them. for the ones which twisted off, once the frames were removed i was able to remove the screw shafts with a vise grip as well. managed to remove all of my frames intact to reuse later. regards, dave
65overlander is offline   Reply With Quote
Old 01-01-2007, 07:06 PM   #12
Profile:  1977 31' Excella 500
Ashland , Virginia
I am in the same process of tearing a 1977 AS down. I think you have a number of good ideas. I found that using an air harmer, the thing you take tires off with, with the right screw head had some luck. If that did not work, I just drilled them out, but will try the easy out tool. I had used it on a Jeep and I had forgotten at how well they work.
good luck, I know I will need ome...
Terapin is offline   Reply With Quote
Old 01-08-2007, 07:34 PM   #13
Jacob D.'s Avatar
Profile:  1964 26' Overlander
San Leandro , California
I separated some of my cabinets from the floor with a pry bar, where a few screws were impossible to remove.
Oh wait, you wanted a gentle approach!
Actually it did very little damage to either the floor or the cabinets in most cases, if you go gently.
Jacob D. is offline   Reply With Quote
Sliding Cabinet Hardware LKappenman Cabinets, Counter Tops & Furnishings 5 10-20-2002 05:53 PM
Cabinet door latches 53flyingcloud Cabinets, Counter Tops & Furnishings 3 07-08-2002 04:28 PM
Door and cabinet knobs jcanavera 2001 Safari 0 07-07-2002 11:19 PM
Cabinet Catches Danno Cabinets, Counter Tops & Furnishings 1 06-18-2002 10:12 AM
Cabinet roll up doors niftypkg Cabinets, Counter Tops & Furnishings 2 05-10-2002 08:22 PM
