Old 10-02-2013, 09:27 AM   #1
2005 28' Safari S/O
Ocean Springs , Mississippi
installing Grass euro hinges
I am trying to replace a Grass hinge on a cabinet door. I can remove the two screws from the mounting plate but the hinge is still as secure as ever.
On a new hinge there appears to be a nylon threaded bushing that the screws are secured in. What is the function of this bushing? How are these bushings anchored into the cabinet door?
How do I remove the old hinge from the cabinet door? Removing the two screws does not loosen the hinge.
Enclosed is two pictures of the hinge showing the bushings.
george1 is offline   Reply With Quote
Old 10-02-2013, 10:24 AM   #2
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
I believe if you depress the tab on the left side in both of your pictures, that should do the trick.
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
