Old 07-22-2010, 05:33 PM   #15
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Ayresdream- you can make wood tracks for lexan, or formica doors, that are fit into (and glued to) the extruded aluminum frame of your overheads. It is roughly a 3/4" by 3/4" wood strip, with saw kerfs spaced a little bit apart for the lexan or formica to slide in. Make the kerfs in the top strip deeper than the bottom ones, and then you'll be able to lift the panels into place and have them captured top and bottom. It's easy with a small table saw, and some construction adhesive. With formica, you can choose from hundreds (thousands?) of colors, patterns, textures, etc. Have fun! -tim
tphan is offline   Reply With Quote
Old 07-28-2010, 07:18 AM   #16
dmroot's Avatar
1971 23' Safari
Portland , Oregon
We used wood strips as the sliders...they have the grooves for the panels cut into them. They work really well.
dmroot is offline   Reply With Quote
Tambour..... Chuck Cabinets, Counter Tops & Furnishings 9 02-18-2016 09:56 PM
Replacing Tambour [Credenza] niftypkg Cabinets, Counter Tops & Furnishings 5 01-16-2007 12:36 PM
Tambour Glue? 74Sovereign Cabinets, Counter Tops & Furnishings 10 10-04-2002 03:05 PM
Tambour Door Resources InsideOut Link Archive 4 09-23-2002 03:12 AM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 08:34 AM
