Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 12-14-2007, 12:41 PM   #1
GLASS GODDESS
Profile:  1966 26' Overlander
Manitou Springs , Colorado
I need Cabinet latches for 1966 Overlander...
Hi Folks, Merry Christmas! This winter I am going to be refinishing the cabinets and several of the latches don't work. I would like to replace them with the original style...does anybody know where I could get some?
Dureedesign is offline   Reply With Quote
Old 12-14-2007, 01:17 PM   #2
1953 Flying Cloud
1953 Flying's Avatar
Profile:  1953 21' Flying Cloud
Sacramento , California
Images: 8
Hinges
Hi there,
I had the same problem. I found this webite that had the same hinges that I needed. I hope they can help you. You might also take a picture of it to show what thy look like. Good luck.
Antique Restoration Hardware for Home Renovators. Supply Yourself With Quality Restoration Hardware for Period Home Renovation Projects.
_______
Robert
Life is like a roller coaster, a whole lot of up's and down's..
1953 Flying is offline   Reply With Quote
Old 12-14-2007, 01:40 PM   #3
byamcaravanner's Avatar
Profile:  1967 28' Ambassador
1963 19' Globetrotter
Waukesha , Wisconsin
Are these the ones you are looking for? ...or are yours the older style?
They are available in white or brown from the vendor shown. :-)
Steve & the crew
'67 Ambassador International Twin
'63 19' Globetrotter
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 12-14-2007, 02:22 PM   #4
Profile:
Special latch
The latch that was used that year, was only for that year from what I have found (but could be wrong). It was a "brushed steel" latch that was about 1 1/4" x 1 1/2" with a latch that lifted up releasing the locking mech. inside. The latch was attached to the cabinet door with the small "L" shape stricker that stuck out forward on the cabnet rail. Trying to find them is like finding hens teeth. Every now and again you see one on eBay. They are a great looking latch, sad it was only used for one year. I looke don the web site from the other post, I did not see them. This very latch is the reason I own 3 1966 Airstreams! It was a very "classy" looking latch!
The photo above was used on trailers from 1967 (top/bottom cabinets), up into the 1970 (for bottom cabinets, top was Tambor, 1971 both top and bottom was tambor)
good luck
Paul Waddell
Region 2 VAC Guy
WDCU "Past Prez" (In the words of Richard Nixon "You won't have me to kick around anymore!")
rideair is offline   Reply With Quote
Old 12-14-2007, 03:17 PM   #5
Commercial Vendor
Profile:  Corona , California
The original 66 latch was not very good, Airstream replaced a bunch of them in warranty. Therefore it was used for just one year.
They have not been available for at least 35 years.
Most owners cut a notch in the side of the doors and install a latch that was used from 1967 to 1970, that is pictured above
Simplfies the problem, and, replacements will be available for many years.
They are available in white and brown.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-14-2007, 03:28 PM   #6
TomW's Avatar
Profile:  1967 26' Overlander
Huntsville , Alabama
FWIW, Andy's picture makes the latch look lighter brown than it is.
I just received 13 of the latches from InlandRV, and all were the same dark brown as my original latches.
The latches appear to be made from the original molds as opposed to being New Old Stock.
Tom
Old 12-14-2007, 03:41 PM   #7
Commercial Vendor
Tom
Tom.
We purchased the original molds from Airstream several years ago.
We do not have any "new old stock" parts.
If you compare the mold marks on the new latches to the old latches, you will see that they are exactly the same.
The only new old stock around Inland RV, is me. , or is it old new stock?
Andy Rogozinski
Inland RV Center
Corona, CA
Replacing cabinet latches chris clark Cabinets, Counter Tops & Furnishings 3 03-06-2007 12:27 PM
Cabinet latches D Bishop Member Introductions 8 10-15-2006 12:10 AM
cabinet latches technautica Cabinets, Counter Tops & Furnishings 9 06-07-2006 09:40 PM
Cabinet/door latches cumminspch The Vendor's Forum 1 11-01-2004 03:39 PM
Cabinet door latches 53flyingcloud Cabinets, Counter Tops & Furnishings 3 07-08-2002 04:28 PM
