Old 03-15-2013, 11:37 AM   #15
Janie Q's Avatar
1972 25' Tradewind
Hammond , Louisiana
I used Loctite Super Glue on a chip here in the house.
Worked perfect.
Jane
I was so mad at myself that I didn't prep.. just glued the back and held it in place till it was dry!
Janie Q is offline   Reply With Quote
Old 03-15-2013, 01:05 PM   #16
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
No glue works on everything (even super glue). Since this was manufactured a long time ago, it may be different than what you'd use today. I'd think about a professional repair because of some chips that may have disappeared and need to be filled in. This is something you'll look at all the time and it is best to have it perfect again.
Throwing up is not what I'd do. I'd be more likely to scream curses—much easier to clean up and my beloved wife is used to it.
Gene
Gene
Old 03-15-2013, 01:33 PM   #17
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Sadly, it's brand spankin' new......I just made it about 2 months ago. :-(
I think I'll play with it tonight. The worst that could happen is that I have to do it over....and spend another fifty bucks on laminate!
Thanks for all the suggestions! I'm not quite as po'd as I was yesterday!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 03-15-2013, 01:51 PM   #18
Protohyp's Avatar
1977 31' Excella 500
Los angeles , California
Send a message via AIM to Protohyp
Oh Becky. Don't worry. we all feel your pain. Since you mentioned now that you were actually the one who laminated it I will go with my original suggestion of doing it over. From the close up of the underside of the laminate it seems you might have been a little lenient with the contact spray? I may be wrong but usually there will be lots of visible fibers or strands of separation of the contact cement in either spray or roll on form. Spray is quick and easy but the roll on contact cement will ensure excellent coverage and under premium conditions will bond for a lifetime.
Protohyp is offline   Reply With Quote
Old 03-15-2013, 07:05 PM   #19
Becky B.'s Avatar
1964 17' Bambi II
Well, I used Land Shark's method of wood glue. It took me a while to get it lined up & even then it's not perfect. I never could have lined it up anywhere close with the contact cement. We'll see what happens after I take the clamps off in 24 hours!Click image for larger version
Thanks all.....I have bigger fish to fry now.....adjusting the stupid table height!!! That thing has been the biggest frustration for me of my whole project. Third time will have to be the charm!
Becky
1964 Bambi II
1988 Avion 32S
Old 03-15-2013, 07:07 PM   #20
Central , Mississippi
I think I have clamp envy
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 03-15-2013, 07:24 PM   #21
Becky B.'s Avatar
1964 17' Bambi II
Harbor Freight, Vernon. Something from there that's actually pretty good & cheap--$3.99 each!
Becky
1964 Bambi II
1988 Avion 32S
Old 03-15-2013, 07:30 PM   #22
reinergirl's Avatar
Hollis , New Hampshire
Wood glue... Wood clamp...hmmm sure hope you put a Teflon sheet or something under them .... If you have glue squeeze out it could be a problem.
With that busy of a pattern I doubt you'll notice it, but I feel for you!
reinergirl is offline   Reply With Quote
Old 03-15-2013, 07:45 PM   #23
Becky B.'s Avatar
1964 17' Bambi II
I squeezed it a bunch of times before I actually left it there. What fun is it if I don't take a small risk, anyhow? More drama is just the story of my life.....
Becky
1964 Bambi II
1988 Avion 32S
Old 03-15-2013, 07:50 PM   #24
reinergirl's Avatar
LOL See? Day two and you already have a sense of humor about it!
Old 03-15-2013, 08:02 PM   #25
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
One thing that you have going in your favor. That boomerang pattern will act as camouflage and make the crack harder to see.
Vaughan
Old 03-16-2013, 06:30 PM   #26
Becky B.'s Avatar
1964 17' Bambi II
Ok, so here are the results......
It's pretty hard to see, unless you're looking for it. It isn't exactly flush on one side/end. I think the chip must have been pretty jagged underneath. Anyhow, I put metal edging on the end so it shouldn't ever happen again! Thanks everyone & Land Shark for all the suggestions! The blood pressure is good again!
Becky
1964 Bambi II
1988 Avion 32S
Old 03-16-2013, 07:58 PM   #27
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
If you can't see it at 4 feet, it doesn't count! Good job! I knew you could do it!
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 03-16-2013, 08:25 PM   #28
Becky B.'s Avatar
1964 17' Bambi II
Thanks, Eljay!
Becky
1964 Bambi II
1988 Avion 32S
