Old 08-27-2011, 10:46 PM   #1
VNO
1975 Argosy 24
Germantown , Tennessee
I can't tell if my cabinets are wood...help!
I am new to my Argosy, and cannot tell if my 1975 cabinets are wood, laminate, or something else altogether.
I'd like to make them pop, but don't know where to start if I can't even identify the material
Anyone have suggestions what to do to it?
Eaglemate is offline   Reply With Quote
Old 08-28-2011, 06:10 AM   #2
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Define "pop" please.. What is is specifically that you are trying to do?
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 08-28-2011, 09:09 AM   #3
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
Our 1973 Argosy cabinets are a veneered wood(wood-grain looking vinyl) I think this was the trend in the '70s...
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Old 08-28-2011, 09:32 AM   #4
DanielB's Avatar
Dark looking wood and plastic must have been luxury items back in the 70s.
What does "pop" mean? Make the cabinets "pop"?
- Andrew Carnegie
Old 08-28-2011, 10:10 AM   #5
VNO
1975 Argosy 24
DanielB, I don't really know what to do with them. I am looking for suggestions. If it's plastic, I guess there isn't much except replace them. Any other ideas. BTW, I have a funny story for ya. Years ago, I was at West Memphis airport test flying a Beech Baron after an oil leak. I was there with just one other guy. A jet pulled in, the doors opened like something out of a movie, smoke poured out, two chicks walked down the stairs, and there was AWWWWW, I FEEL GOOD. James Brown. We spent about an hour shooting the breeze. He was on his way to play Tunica. It's a story I'll never forget.
Old 08-28-2011, 10:42 AM   #6
DanielB's Avatar
James Brown.. awesome.
I don't know about cabinets.
- Andrew Carnegie
Old 08-28-2011, 10:49 AM   #7
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Thumbs up
James Brown played at prom (Chicago Lane Tech 1969) He could really move!
Can you paint or retexture or laminate your surfaces? Before you replace it seems you could freely experiment and use your creativity. I have seen someone even use fabric to good advantage to cover their fronts.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 08-28-2011, 11:08 AM   #8
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
If your '75 Argosy24 has its original cabinetry, it's a plastic woodgrain laminate over the structure of the cabinetry. One attractive option (the one the previous owner of my Argosy used on some of the surfaces) is to remove the plastic laminate and re-cover the area with high quality wallpaper. This works better if you remove all the edge trim first, then re-install it after for a nice finished look. In mine, he used a textured fabric sort of wall covering, and I'm very happy with the results. The lower locker doors and the center bulkhead are still the original woodgrain, as well as the door of the refrigerator. It's a good balance for me.
— David
Old 08-28-2011, 11:38 AM   #9
DanielB's Avatar
I have never seen this thought expressed on this forum. I need to start reading the women's threads..
- Andrew Carnegie
Old 08-28-2011, 11:59 AM   #10
my3sonsdad's Avatar
1975 Argosy 26
1979 30' Argosy
Vienna , VIRGINIA
Would a wood veneer like cherry or birch adhere to the existing panels (minus the laminate)?
1975 Argosy 26
1979 Argosy 30
2015 Jeep GC Summit EcoDiesel w/Hensley
my3sonsdad is offline   Reply With Quote
Old 08-28-2011, 12:01 PM   #11
DKB_SATX's Avatar
1976 Argosy 28
Originally Posted by my3sonsdad
Would a wood veneer like cherry or birch adhere the existing panels?
If I were going to try that, I think I'd peel/scrape off the original laminate and put the new onto the original substrate.
— David
Old 08-28-2011, 12:03 PM   #12
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
I am working with ours and overlaying some of the existing panels with a formica-type laminate. I found some white for the bathroom and cherry wood-grain for the living area for $5 a sheet at our local habitat re-store...
Old 08-28-2011, 12:45 PM   #13
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
When you scrape laminate you end up with uneven glue residue, if you cover old laminate what will stick to it and new laminate?
Old 08-29-2011, 06:12 PM   #14
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Remove the residue as best as possible-laquer thinner (I did this with a counter-top I broke) and reapply with more contact cement.
What kind of wood was used in 1967 Safari bamurphree Upholstery, Blinds, Walls & Interior Finishes 15 10-17-2013 03:10 PM
To wood or not to wood? warrenivan Classic Motorhomes 20 11-07-2011 08:38 PM
Feast of Spring Rally at Penn Wood Airstream Park PA Camper WBCCI Rallies & Events 0 04-06-2011 07:14 PM
Take up Cabinets? angela123go Floor Finishes 3 03-17-2011 11:54 AM
Workamping Opportunity At Penn Wood Airstream Park DEITZ645 Working on the Road 0 03-14-2011 12:58 PM
