Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 01-18-2007, 05:53 PM   #1
Foiled Again's Avatar
Virginia Beach , Virginia
Hydraulic lift table?
I sew and work on the computer a lot. I have the FB SE with the rear dinette and the table is about 4 inches too high to comfortably use for typing or as a sewing machine table.
I've been thinking a lot about a pump up lift system - from a beauty salon/barber chair, or even an office chair minus the wheels as a height adjustable center post for my table. Of course I'd also have to detach it from the wall but have some kind of restraint when traveling.
Has anyone else done this? I think I remember seeing something similar on this forum several years ago.
Ideas?
Paula Ford
Old 01-18-2007, 06:11 PM   #2
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Paula,
My mom has a sewing machine cabinet with some type of lift system in it. I suspect the one off the hair chair is going to be too heavy. My dad built the cabinet. I know you can buy parts from somewhere like Rockler
This the mechanism I was talking about.
Aaron
WBCCI #2449 AIR #2495
Old 01-18-2007, 06:22 PM   #3
Certifiable
mistral blue's Avatar
Profile:  1977 Argosy 24
Beautiful , New England
I think I heard that Colin Hyde of GSM in Plattsburgh, NY was playing around with an adjustable table for a client. I might be wrong, but I think he was indeed using a barber chair-like device.
mistral blue is offline   Reply With Quote
Old 01-18-2007, 08:38 PM   #4
MarkE's Avatar
Profile:
How about one of those infinitly adjustable bed-side tables, as used in hospitals, nursing homes, etc?
'Just an idea.
MarkE
WBCCI #4568
MarkE is offline   Reply With Quote
Old 01-18-2007, 09:34 PM   #5
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
I remember seeing a screw jack with a small metal platform and it was powered by the 12 v. plug coming from your truck to trailer connection. I looked through my Harbor Freight tools catalog and didn't see it there. It was either in my Global Industrial, Cabela's or Bass Pro Shops catalog but I can't remember which one.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-20-2007, 10:23 PM   #6
'Just an idea.
You may have an idea there!!! I just wonder if they can crank low enough to use the table as a bed - about 18 inches. I'll check it out, thanks.
Paula
Old 01-21-2007, 02:45 AM   #7
Found on Ebay
eBay Motors: Adjustable Table Leg for your RV/Camper/Motorhome (item 230077006508 end time Feb-10-07 05:23:53 PST)
not hydraulic but at least it's adjustable. Of course I'd need 4....
Paula
I'm also thinking of ripping the legs off of a decent ironing board!
Old 01-21-2007, 09:37 AM   #8
buckwheat's Avatar
Profile:  North central , Alabama
For the really cool solutions, look for boat stuff!
Garelick Marine Products
Converts dinettes to berths
9" (23cm) diameter cast aluminum base on each end for support
Lock to any height frm 14-1/2" to 30-3/4" (37-78 cm)
Only $130!
BubbleHead Fred
"Underway is the only way!"
buckwheat is offline   Reply With Quote
Old 01-23-2007, 09:33 AM   #9
Really Cool!
Thanks for that link. The only problem that I saw was that "in lowered position the inside tube goes 6" below the deck. (sigh).
I think gas lift just isn't going to work. The lowest the table needs to go is 19" to use the bed option. I also would like the table to be movable - when I'm sewing I need to push the table away from me. I think I'll get just get the adjustable legs I found on e-bay. Mount two of them close together on the open end, and two farther apart in the back. I can then detach the table from the wall and drop it to desk/sewing table height when parked, bed height when underway.
Thanks for the link though. Paula
Old 01-23-2007, 09:57 AM   #10
troubleskeep's Avatar
Profile:  1979 31' Sovereign
Richmond , Virginia
Wonder if you could use one of the airbags from a suspension system, use a small compressor to lift it up, air down to lower. Bag should be very light but able to hold huge amount of weight. Even with a small compressor built in, it should be very light, the material to make the table would be heavier.
Well, it was a thought anyway.
  • My mind is like an aluminum trap! Anything caught inside gets turned into an Airstream on the lake.
-Barry & Lisa J
'79 Soverign International @ 31'
2006 GMC Sierra 4x4 2500HD 6.6L Duramax
2001 GMC Sierra 4x4 1500
troubleskeep is offline   Reply With Quote
Old 01-23-2007, 11:36 AM   #11
DayStreamer
grizzy's Avatar
Profile:  2001 19' Bambi
Mesa , Arizona
You might want to check out the following, they have quite a variety depending on how much you want to spend.
Amazon.com: table pedestal - Boating: Sports & Outdoors
Dave
DayStreamer
2001 19' Bambi
02 Avalanche
Mesa Arizona
AIR #5591
grizzy is offline   Reply With Quote
Old 01-23-2007, 01:44 PM   #12
Round on both ends
SafeHarbor's Avatar
Profile:  1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Or you could cannibalize one of the 240-lb "executive" office chairs found at Staples, etc. The bottom of the base cushions have a flat surface and the chairs have a big lever sticking out the side for up-down adjustment. The disadvantage is that you have to lift the weight off to go up.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 01-24-2007, 09:38 AM   #13
Best yet!
But OUCH - the one that lists height as metric - 450mm is 18 inches. I need 14.5 inches for the dinette to function as a bed. It's 19 inches to the top of the cushions. The Gerlick manual one that goes to 14.5 inches has the tube protruding 6 inches below the deck. The two stage gas lift ones (I ain't that rich or that crazy!).
I'm going to look around a bit more, but this may be what I choose. I'll check some local marine stores too - hey I'm on the ocean.
Paula Ford
They say I'm rotten to the core.... but that I'm great to the fleet!
(Marine Corps)
Old 03-09-2007, 07:46 PM   #14
Update
I bought the height adjustable legs from Dyers RV and installed them on my table. Well that's a bust. These legs are too wobbly to support the table without it being attached to the wall. They are dark brown which matches the Midnight Sun interior nicely. I can't send them back because they were only 30 inches tall and I had to drill an additional hole to raise them to 30.5 inches to fit the standard Airstream table height. I'll take them to some rallies this summer... surely I'll find a vintage owner who needs to rebuild a dinette and they'll find a home. Meanwhile back at the ranch... I'm using a small portable table to sew on, but there's so little free floor space it's kind of a pain in the neck to have it set up.
Back to the drawing board...
Paula
Today is a gift. That's why they call it "the present"
Body Lift?? Morning Dew Axles 2 04-18-2004 06:53 PM
Pedestal Table eraffety Airstream Motorhome Forums 7 11-08-2002 08:02 AM
New Front Credenza/folding table j54mark Cabinets, Counter Tops & Furnishings 5 11-07-2002 06:32 PM
Reese Electra Lift Road Ruler Jacks, Stabilizers, Lifting and Leveling 0 08-22-2002 05:12 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 06:02 PM
