Old 03-09-2007, 07:04 PM   #15
Certifiable
mistral blue's Avatar
If you can get your hands on the Spring 2007 issue of Airstream Life, and turn to page 27, they briefly describe (and show) a table mounted on a hydraulic pedestal which might provide you with some inspiration. Good luck Paula.
mistral blue is offline   Reply With Quote
Old 06-09-2016, 05:16 PM   #16
1972 25' Tradewind
1976 31' Excella 500
Denver , Colorado
This post comes up when searching for a hydraulic lift solution for dinette to bed solutions, so I'm posting here.
I was thinking about using a floor jack from Harbor Freight. I would obviously need to do some engineering/building as far as getting the lift attached to a table top, as well as creating the support from the lifting surface to the bottom of the table, but there are several floor jacks with a 15" lift, so it should work as far as the amount of travel goes. Not to mention they are designed to hold 3 tons, so there shouldn't be any issue with whatever you might set on the table!
I also saw (), which is intriguing. It seems a little rickety (wobbles when they are showing it off), but for $70 it seems like maybe it's worth giving it a shot. It was kind of funny just how much time it took me to track down ANY real information about buying the thing, but it's called the Snap 2 Folding Table Base (V-40). I finally found it on FactoryRvSurplus.com.
Most of the links to products regarding this issue on various RV forums are to dead links, or the products mentioned are no longer listed on the various RV and Camping site. I wonder why (do the multi-stage table lifts just not work?).
25' 1972 Airstream Trade Wind Land Yacht
2006 Jeep Liberty CRD (diesel)
http://BeahmStream.com
kidjedi is offline   Reply With Quote
New Front Credenza/folding table j54mark Cabinets, Counter Tops & Furnishings 6 09-20-2011 07:35 PM
Body Lift?? Morning Dew Axles 2 04-18-2004 05:53 PM
Pedestal Table eraffety Airstream Motorhome Forums 7 11-08-2002 07:02 AM
Reese Electra Lift Road Ruler Jacks, Stabilizers, Lifting and Leveling 0 08-22-2002 04:12 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
