Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 11-01-2006, 11:21 PM   #1
Commercial Vendor
soldiermedic's Avatar
Profile:  1975 29' Ambassador
1953 21' Flying Cloud
O'fallon , Missouri
Send a message via Yahoo to soldiermedic
Question How would you fix me?
Anyone have any ideas? I thought about fabricating a new wood trim piece to cover it.
Name:	front compartment.jpg
soldiermedic is offline   Reply With Quote
Old 11-02-2006, 05:58 AM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Looks like somebody had a tv set in there. You could do as you suggest, and use a larger piece of wood to cover up the problem area, or you could use fiberglass mat and resin to remake the area.
(No Longer at Inland RV)
Old 11-02-2006, 06:13 AM   #3
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
larger trim might look out of place, i would attempt to repair the area as terry suggested.
if it doesn't turn out you could still cover it up.
john
you call them ferrets, i call them weasels.
Old 11-02-2006, 06:58 AM   #4
Still Working
smily's Avatar
Profile:  North Charleston , South Carolina
Capitalize
I would cut out the rest of the header and make a box or shelf to fill void.
I have actually seen where folks add a wire screen shelf above this ridge for additional storage and I have seen it done with oak shelf rail with little banister or spokes, it looked like it was OEM.
I think you are asking for a big mess by truing to repair with fiberglass. If you are not experienced with fiberglass, it is a real headache.
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 11-02-2006, 07:35 AM   #5
Commercial Vendor
O'fallon , Missouri
I have zero fiberglass experience, but dont want to cut the header out as it will be nice storage for radio, dvd, etc. Plus I don't want to remove it for the sake of keeping it as whole as possible.
Old 11-02-2006, 07:49 AM   #6
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
it is not that hard, there is a learning curve when working with it. it is just fiberglass cloth and a 2 part epoxy.
try practicing with it on a sheet of plastic or newspaper when you have the skills try it on the trailer.
you may have to construct some kind of backing for it while it sets. kinda like paper mache projects kids do over ballons.
john
Old 11-02-2006, 08:58 AM   #7
maxandgeorgia's Avatar
Profile:  1995 30' Limited
Ashland , Missouri
I think that if you had a wood trim piece that matches the current trim closely that you could "step" up the trim by adding a piece straight across the top of the storage unit, stopping or 'stepping" down where the end curves begin. It doesn't have to be very wide, just enough to cover the gap. Easy fix, and will look nice, like it had always been there, in my opinion. ~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 11-02-2006, 10:14 AM   #8
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
The way I did it was to make up a plywood or luan part as a mould, wax it lay over the fiberglass with resin.
When you remove it, it will have the super smooth finish you need.
Or makeup a complete overlay out of wood, and stain to finish.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 11-02-2006, 10:23 AM   #9
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
I think John's suggestion makes a lot of sense. Try to glass it first, if it doesn't come out just right the first time it's called learning. The next time will be better. Remember you can shape it to some extent by grinding/sanding. Just make sure you use respiratory protection.
As has been stated, you can do something with wood if glassing it doesn't produce an acceptable result. Fiberglass will keep it most original.
Dave
Fyrzowt is offline   Reply With Quote
Old 11-02-2006, 10:53 AM   #10
Daedalus's Avatar
Profile:  1973 26' Argosy 26
Stone Ridge , New York
How about drilling styrene dowels into the existing plastic for a strong mechanical connection, and then attaching styrene "mini-ribs" w/ adhesive to re-create the curve of the original piece. When that is done you can get busy with the fiberglass. It's messy, so practice on your corvette but it's very easy to do. When it hardens you just add more layers as need be. Once you have a good strong fiberglass shape you can add bondo and sand, sand sand. As far as the woodwork you can either redo all of it or patch it as required.
See attached (I hope) pics
By the way congrats on your Safari find.
Don
ID:	27935   Click image for larger version
Daedalus is offline   Reply With Quote
Old 11-02-2006, 10:56 AM   #11
Fyrzowt's Avatar
Images: 8
Wow, that was fast! Don't change anything!
Old 11-02-2006, 10:57 AM   #12
Mel
Mel's Avatar
Profile:  1967 22' Safari
1960 18' "Footer"
Edmonds , Washington
Don - what a helpful first post (and with pictures, too!) Welcome to the forums!
Mel
1960 Caravel "Boris"
1967 Safari "Sparky"
WBCCI BC Unit #4258
Mel is offline   Reply With Quote
Old 11-02-2006, 11:00 AM   #13
Daedalus's Avatar
Mel thanks for your comments. Now I must get back to work or I might have to fire myself.
Old 11-02-2006, 11:02 AM   #14
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Neat
Don, Is that all done with photoshop????? That was impresive work.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Wish AND FIX UP list for MH PeterH-79MH Mechanics Corner - Engines, Transmission & More... 35 07-25-2009 10:49 AM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 10:59 PM
Broken Lite Shade Fix wagsrp General Interior Topics 1 10-13-2002 10:11 AM
How do you fix the entry step. rdm Airstream Motorhome Forums 2 07-14-2002 10:16 PM
wiring fix? ALANSD Airstream Motorhome Forums 9 06-20-2002 08:40 AM
