Old 12-04-2010, 03:59 PM   #1
star kitty's Avatar
1967 20' Globetrotter
denver , Colorado
How to repair bathroom cabinet veneer?
In an attempt to maintain the originality of the trailer, I want to keep the vinyl veneer in the bathroom. It covers the walls and the cabinets. Problem is, its de-laminating near the edges of the wooden frame of the doors. In some areas, the veneer has started to bend away from the wood frame. I have applied contact cement, but because of the distorted surface, it just goes back to the position it has been in for years. Has anyone tried to keep/repair this veneer in their unit? Will the "gentle" use of a heat gun remove the veneer and will I be able to get it back to the original shape and then re-glue it?
If not, what glue have you guys found that will keep the edges attached?
Thank you!
star kitty is offline   Reply With Quote
Old 12-04-2010, 04:46 PM   #2
nick6930's Avatar
1979 Argosy 27
1969 21' Globetrotter
1953 25' Cruiser
Front Royal , Virginia
With formica I have very good luck using an iron on a low setting to heat up the old glue. I would try to heat it up to make it more pliable and then add the contact cement. Some boards and a clamp to straighten out the veneer til it dries.
nick6930 is offline   Reply With Quote
Old 12-04-2010, 06:06 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I had several panel that were completely delaminated. I was able to use a "mouse" sander and 80 grit to remove all the old adhesive and bits of plywood and then used laminate contact cement to re-attach it to the substrate. If it is just an edge the iron may work.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 12-05-2010, 06:54 PM   #4
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
If that fails, as a plan B, you could trim the edges to conceal the lifting. If you pre-caulk the trim before attaching it, you'll prevent further moisture entering the seam.
TX-16
Dave Park is offline   Reply With Quote
Bathroom cabinet doors handn 2004 Safari 5 06-13-2018 07:08 PM
Bathroom cabinet latch is junk- 2006 Classic kleimanr 2006 - 2010 Classic (all lengths) 7 07-25-2014 02:05 PM
Help and advice needed, bathroom cabinet. lebolewis Cabinets, Counter Tops & Furnishings 5 04-10-2010 07:05 PM
73 Overlander bathroom cabinet mirror removal / Help? Lothlorian Cabinets, Counter Tops & Furnishings 2 07-13-2009 07:09 AM
70's veneer and bathroom trim davidz71 Cabinets, Counter Tops & Furnishings 4 03-26-2004 07:58 AM
