Old 06-22-2011, 01:43 PM   #1
Bfrank's Avatar
1979 24' Airstream Excella 24
Adams , Tennessee
How to remove cabinet?
I have a 79 MH and the overhead kitchen cabinet that has two tambor sliding doors. It needs to be removed and repaired one side is drooping badly. My question would be how is the trim peice attached to the inner skn of the inner roof panel. mine has a long strip on the edge of the inner roof panel and only one rivet at the front end behind the head liner with what looks to be a small end trim cap. Do I drill the rivet and then remove the trim from the side edge of the inner roof panel to get to the rivets that are holding the cabinet up? It is one long peice of trim that looks to be slipped over the edge of the center roof panel? Hopefully I don't have to remove the inner skin from the roof because I think I would have to remove the divider curtain the wall at the end of the cabnet the inside A/C shroud the roof vents etc so any one that has done this can I get some tips for the removal? I'll try to post some pics in this and see what happens. I need to do this right the first time. Thanks
ID:	133027   Click image for larger version
Frank & Lisa Sullivan
Bfrank is offline   Reply With Quote
RemovAll 220 - will it remove old caulk? malconium Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-21-2011 09:26 PM
2003 safari - how do you remove black water tank? greenrvlife Waste Systems, Tanks & Totes 3 04-08-2011 11:15 PM
How to remove slip hub / flange 1970 3/4 bath silversafari Waste Systems, Tanks & Totes 2 02-27-2011 08:40 AM
How to remove door from trailer? nm1oqrz Doors & Locks 2 02-16-2011 08:57 PM
Before I remove bath end cap Breadbug Ribs, Skins & Rivets 3 01-27-2011 02:03 PM
