Old 01-18-2011, 05:02 PM   #1
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
How to build a dinette
This is my first attempt at building a dinette and I can certainly use all the help I can get. I have studied a number of threads on building dinettes and it seems that almost anything goes - from building a basic framework then facing it whatever it is faced with to building the framework out of the birch (or whatever) that is the facing itself.
I have a number of considerations:
1. It is a small trailer (18' tongue to end)
2. It is meant for just two adults and maybe a grandkid
3. There is a fresh water tank, the water pump and the converter in the front of the trailer - all of which needs to be hidden.
4. The fuse boxes are near the water tank.
5. The streetside bench will go from the end of the galley cabinet to the front wall.
6. The curbside bench can only go from the door opening to the front wall.
7. I would like to have storage under the benches and/or behind the backs of the benches.
8. I would like the table to drop down so that it makes into a twin sized bed.
9. It is not necessary to seat anybody over the water tank.
10. I don't know how to attach the table to the wall.
11. What is best - pedestal leg for the table or fold-up leg?
I've posted pictures of the space available and a drawing of the space with measurements. Any help, advice, support, guidance or offer of free labor would be greatly appreciated.
Thanks in advance -
Lindy
ID:	119616   Click image for larger version
lucymcdog is offline   Reply With Quote
Old 01-18-2011, 05:33 PM   #2
OO , OO
Send a message via Skype™ to cruiser54
Hi Lindy
For my Cruiser I have drawn many variations and at the end I came on 2 benches with rectangular table.
Does a semicircular bench with a semicircular table in the middle? The table can be folded to a round one if several people are to food. Maybe teleskop table leg to let down for bed make?
Excuse my English, I must translate with the computer....
Greetings from Switzerland
Werner
cruiser54 is offline   Reply With Quote
Old 01-18-2011, 05:56 PM   #3
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Here is the dinette I made in our Caravel, replacing the front 3/4 gaucho.
It does not make into a bed, but could be constructed to do so.
The fresh water tank is the same place as yours.
I made storage above the tank with two sliding doors.
The shelf above the water tank is just wide enough to hold the microwave. That shelf is wired for 120v, 12v, and has the cable connection to the outside of the trailer.
I used the storage bins and doors that were under the gaucho.
I cut the original cushions down. They had plywood bottoms, so just folded and stapled the cut ends, which ended up against the storage cabinet. You need to cut the foam about two inches long so that the cloth material will be tight when finished.
The table is connected using a table rail attachment available from most RV parts stores. I got an extra rail and installed it on the inside of the entry door, so that when the door is open, the table can be moved outside. The leg on the table is an adjustable awning pole. It can be adjusted to the right height when inside or when outside when the table is hung on the door. By doing this, we don't need to carry a table for use outside.
I used much of the material and frame work from the original gaucho. I bought one sheet of 4x8x1/8 plywood door skin and one sheet of 4x8x3/8 mahogany on one side plywood, and two 2x2x8' pieces of pine for framework.
I did the whole thing in two days for under $200.00.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 01-19-2011, 07:07 AM   #4
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Wow! what a deal - 2 days and $200!
I have some questions for you.
What did you use for the "tracks" for your sliding doors? My top cabinets in the galley and bedroom have really nice shiny metal tracks for the sliding doors but I have been unable to find any more to build more cabinets. I like that the doors slide there in the front so they don't take up any space.
Is your table rail attached to the little cabinet that covers the water tank?
Did you build a framework then put the 1/8" plywood over the frame?
How did you stabilize your water tank so it wouldn't move around?
How did you attach the awning pole to the table?
Did you keep the plywood bottoms on the cushions or did you put a plywood base over your framework and put the cushions on that?
Is there a "lip" on the edge of the bench to keep the cushions in place?
Thanks for your help!
Lindy
Old 01-19-2011, 09:04 AM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
For the tracks I used a plastic double window channel from a marine supply. They are used in boats.
I attached it to a piece of 2x2 frame supporting the shelf.
Yes
It had small 1x2 blocks holding it in place.
The table had a folding leg pole which I replaced with the awning pole.
Kept the wood in the cushions, used the existing wood in the frame from the old gaucho for support.
Yes, it was on the gaucho.
Lindy
Hope this helps.
Old 01-19-2011, 09:12 AM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Here are some shots of the rough in to give you some ideas. You can use the "panel" method that I used for the support frame or go with a "stick built" frame assembly. I used pocket screws for fasteners on all of the frame assembly as well as to attach it to the floor.
With the table down the bed dimensions are 42"x76". I can fill in the details later if you wish.
My water tank is across the front similar to yours.
ID:	119655   Click image for larger version
Name:	New Dinnette.jpg
TG Twinkie is online now   Reply With Quote
Old 01-19-2011, 09:18 AM   #7
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Here's a link to our webpage which shows our '64 GT's dinette. There are also links to the hardware we used - ours makes down into a bed, but does not have the water tank up front.
Shari
Old 01-19-2011, 08:25 PM   #8
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Thanks for the pictures. Is your water tank inside the small box between the seats? Is it just anchored with the box itself or does it need more stabilizing?
It doesn't look like your seats have any kind of lip to them to keep the cushions in place. Did that come later or do they stay in place without it?
Do you access the storage space by lifting up the seat?
Its really helpful to see different ways of doing it - looks like there isn't necessarily a "right" way so I think we will take some ideas from different ones and see if we can make them work.
It's off to Home Depot tomorrow - an all day trip - so we won't get anything done on it tomorrow. But we'll be ready to get to work by Friday! I'll post pictures of the progress - although I think it may take more than 2 days to finish it.
Old 01-19-2011, 10:22 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Is your water tank inside the small box between the seats? Is it just anchored with the box itself or does it need more stabilizing? The tank goes all the way across the front of the trailer. If you look closely you can see it in the right and left hand corner; it is aqua blue. The box holds it in place; I didn't want any sharp edges like blocks rubbing on the tank. If you click on the image it should get larger. Then go to View; then Zoom to 200%
It doesn't look like your seats have any kind of lip to them to keep the cushions in place. There is a 3/4" lip on the front edge of the seat. Haven't had any problem with them moving.
Do you access the storage space by lifting up the seat? Yes, there are hand holes to lift them out. I thought about putting drawers in; but decided there would be too much wasted space, with the drawer slides and the fact that the drawer has to be at least an inch narrower than the opening.
Old 01-19-2011, 11:52 PM   #10
the544man's Avatar
1956 16' Bubble
Dallas , Oregon
Why not move your water tank? Then you could build it however you want. I'm in the process of rebuilding a 16 foot bubble and started with a stripped out interior. You can see the dinette design and pics on pages 3 and 4 of my thread. http://www.airforums.com/forums/f44/...h-62815-3.html It's not that hard to plumb new lines with pex. Just a thought for you since it looks like you're starting from scratch like me. take your time and make your plan firm. the dinette/bed is the most used spot in a trailer so it's good you're giving alot of priority. Cheers. Ted
the544man is offline   Reply With Quote
Old 01-20-2011, 06:50 AM   #11
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
I was going to move the tank to under the bed then decided, weight wise, I should put it back where it was originally. So now I'll just build around it.
What a beautiful little trailer you have! I really like the little ones...
Old 01-20-2011, 06:58 AM   #12
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
When you built your "panel" did you do that in place or outside the trailer and then bring it in? I'm thinking of doing a combination of yours and Jim's trailer - have a shelf in the front with sliding cabinet doors so I can access the area and then maybe do the panel on the front of the seats. I have found some "perforated" metal that matches the panels on the cabinet above the fridge and thought that might work - as well as give me the ventilation I need for the converter.
Could you fill me in somewhat on how you build the framework? And how high are the panels that the cushions sit on? Is 24" for the seat depth pretty much standard? I'd like to have a slanted back so I will have to take that into consideration when measuring for the seat area. Is a 5% slant about right?
Today will be a good day to go spend $$ at Home Depot. It is 3 degrees outside and the wind is blowing 40 mph. That's winter in the valley...
Old 01-20-2011, 07:45 AM   #13
InsideOut's Avatar
1956 22' Safari
Images: 108
The typical slant for dinette (& chair) backs is 12.5%...that's what we built in to ours.
Shari
Old 01-20-2011, 08:09 AM   #14
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Hi Lindy,
Here's a link to some sliding door tracks:
4 Foot Plastic Sliding Door Track - Rockler Woodworking Tools
Chris
dinette, table
looking for early Argosy 24' with twin and dinette turfclubroad Argosy Motorhomes 2 02-03-2011 02:56 AM
