Old 10-02-2011, 09:02 PM   #1
dznf0g's Avatar
Oswego , Illinois
How to attach aluminum backsplash
I am installing clear coated aluminum as a backsplash in my bathroom just like in the galley. The sides and top will be captured behind the walls and mirror cabinet respectively.
My question is how to secure it to the paneling so it will follow the curve of the wall and be stable enough so caulk will adhere well along the countertop/backsplash interface.
Do I use adhesive, screws, or something else?
The galley doesn't seem to have any mechanical mounting at all???????
-Rich-
Old 10-02-2011, 09:22 PM   #2
timmaah's Avatar
1999 25' Safari
On , the road
I'm about to do the same. I figure the loctite construction adhesive will work well. Trowel the bead down and use a laminate roller. Don't see how that would move anywhere.
timmaah is offline   Reply With Quote
Old 10-02-2011, 09:36 PM   #3
dznf0g's Avatar
Oswego , Illinois
Does it remain somewhat flexible. I gotta believe there's some flexing and movement while traveling?
-Rich-
Old 10-02-2011, 10:01 PM   #4
timmaah's Avatar
1999 25' Safari
On , the road
In my opinion it shouldn't go anywhere. For some extra security I will probably end up putting a rivet or screw in some hidden spots. In my trailer it didn't take much to take the counter top off. Then you can have all four sides behind another surface. No way it will move.
Old 10-02-2011, 10:54 PM   #5
Ottawa , ON
Classic Ride's DIY series' .
Old 10-02-2011, 11:05 PM   #6
1973 23' Safari
Encino , California
contact cement. spray two even coats on each surface allow to dry. place 6 mil plastic or thicker in between. Contact cement will not stick to the plastic allowing you the luxury of seeing where you are and properly placing the material. Gradually you work the plastic down behind the material. Work down the middle and toward each side a little at a time.
Land Shark is offline   Reply With Quote
Old 10-02-2011, 11:20 PM   #7
Ottawa , ON
Jeez, the DIY guys just used construction adhesive. It takes a while to set, so you can still move the metal around, but is a lot simpler. The rivets ensure that nothing is going to go anywhere.
Old 10-03-2011, 06:30 AM   #8
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Why not do as Airstream does? Use a few rivets.
Old 10-03-2011, 07:13 AM   #9
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I want to do something similar, but was thinking about stainless square/ diamond pattern you see in old diners. Does anyone know a source?
Looking at the video I am guessing this material is easier to work with. Where can I get it?
I am also thinking about re-skining my door. What type of aluminum should I get? and do you know a source?
Lumatic is online now   Reply With Quote
Old 10-03-2011, 07:58 AM   #10
dznf0g's Avatar
Oswego , Illinois
There are no rivets in my galley. The overhead cabinets, spice rack, levels monitor, ac outlet, cupboard, window frame are all the mechanical attachments through the back splash. That is what makes me think there must be some adheasive there. Also, in the bath, I would be riveting through the wallboard as well as the interior skin. Is that an issue?
Old 10-03-2011, 08:04 AM   #11
dznf0g's Avatar
Oswego , Illinois
Duh...I didn't even think about capturing behind the countertop. That's probably all I need to keep it in place. The space is only 11" tall X 43" wide.
Old 10-03-2011, 09:39 AM   #12
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by dznf0g View Post
<snip>Also, in the bath, I would be riveting through the wallboard as well as the interior skin. Is that an issue?
We used full height stainless steel sheets in our wet bath on the backside of the wallboards. We used solvent-based contact cement to adhere the two together and tucked the edges in the trim along the wall. We also used stainless steel acorn nuts to attach the towel bar and sink on one wall (behind the dinette) and a few below the cabinet height of our kitchen on the other wall so you can't see them from the outside of the bathroom - all you see is wood. All of the rivet/screw, pipe, drain penetrations & edges were sealed with Vulkem - our bathroom is water tight. The curved exterior walls are just sprayed with the AIM Zolatone (as like the rest of the trailer) - it's an epoxy-like finsh that seals the joints & rivets in the aluminum.
The reason we used stainless steel rather than aluminum is that it is much easier to keep clean because the aluminum would oxidize from all the moisture in the shower.
Some pics of our bath under construction can be seen in post #369
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 10-03-2011, 10:01 AM   #13
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
The metal stamped sheets are prone to denting and, once dented, are impossible to repair. You can buy at HD plastic sheets that are practically indestructable and impossible to tell from the real thing. There are edge strips available
I used them as a splash for the wall above the sink at the end of my galley counter and to cover damage on the microwave cabinet. Apply them with double-sided tape. I also used the sheets as the insert on my new refrigerator.
HD stocks a limited number of patterns and colors, but you can order a wide variety from the brochures they have at the display.
ID:	141518   Click image for larger version
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 10-03-2011, 12:11 PM   #14
casarodante's Avatar
2012 31' Classic
John, I am thinking of putting that on our curved outside wall. I did something similar to yours on the side wall (at this thread) with stainless. But I want something better that contact paper but more flexible that the stainless. Looks like the ticket. Here is what we have now (but everything is reattached ):
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 10-03-2011, 01:44 PM   #15
1966 30' Sovereign
Mount clemens , Michigan
What about 3m VHB tape. I bought some but have not used it yet. Search Google for it and watch some of the videos. If it does what it claims it can do then I am going to use it a lot on my trailer.
Brianv512 is offline   Reply With Quote
Old 10-03-2011, 03:04 PM   #16
Contributing Member
Pahaska's Avatar
It will take a gentle curve such as your wall in one plane very nicely. There are several styles that have no raised ribs that would curve more tightly.
I didn't show my refrigerator front, but just about everyone who tours the trailer comments on it.
John W. Irwin
WBCCI #9632
Old 10-03-2011, 03:51 PM   #17
ctdair's Avatar
I put Mine up In 2 pieces as that is what I had. I riveted along the seam mimicking the belt line on some trailers. Picture has a lot of flash glare but You can see most of the rivets. The lapped seam is upside down that just was the way it worked out with some damage to one of the pieces I needed to hide.
Name:	Nova Rally 019.jpg
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2010 Dodge 2500 Diesel 4x4 Megacab
ctdair is offline   Reply With Quote
Old 10-03-2011, 05:31 PM   #18
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
I used the Vulcum same as the original skin panels
'77 Sovereign Intl 31' CB
Old 10-03-2011, 05:52 PM   #19
1993 21' Sovereign
I missed that part. Oops. Good thing you didn't take my advice and start riveting for all you were worth, it could have been--messy...
Old 10-03-2011, 06:15 PM   #20
Contributing Member
Pahaska's Avatar
Fridge face
Here is a shot of my refrigerator face with the plastic replica stamped aluminum. The sheets are affixed with double-sided tape and black plastic screen spline is tucked in around the periphery to adjust for the lack of thickness compared to the Dometic panels.
John W. Irwin
WBCCI #9632
Aluminum desk top worksology Cabinets, Counter Tops & Furnishings 33 06-30-2011 06:47 AM
Lug nut torque for aluminum wheels? blickcd Wheels, Hubs & Bearings 5 05-01-2011 09:08 PM
Coated Aluminum glh101282 Clearcoat, Exterior Paint & Trim 6 02-24-2011 11:38 PM
