Old 03-04-2012, 05:52 AM   #29
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
aluminum interior
Got the backsplash done yesterday. Decided to use 3M super 77 as a contact cement after removing the lower portion of the cabinet.
Your job looks great that you did last year. Did you end up using the aluminum "look" laminate in the DIY video? Did you just do the backsplash area or take out the cupboards?
Old 03-04-2012, 06:41 AM   #30
dznf0g's Avatar
Oswego , Illinois
I used a piece of clear coated exterior skin. The same as was installed as the kitchen backsplash. I did take out the cupboard and trapped the skin under the edge of the cupboard. I found it unnecessary to remove the counter top. The clamping force of the cupboard and the adhesive hold it in place very well along the lower edge of the aluminum. Just caulked with a silver caulk and it holds nicely.
-Rich-
Aluminum desk top worksology Cabinets, Counter Tops & Furnishings 33 06-30-2011 05:47 AM
Lug nut torque for aluminum wheels? blickcd Wheels, Hubs & Bearings 5 05-01-2011 08:08 PM
Coated Aluminum glh101282 Clearcoat, Exterior Paint & Trim 6 02-24-2011 10:38 PM
