Old 10-03-2011, 12:44 PM   #15
1966 30' Sovereign
Mount clemens , Michigan
What about 3m VHB tape. I bought some but have not used it yet. Search Google for it and watch some of the videos. If it does what it claims it can do then I am going to use it a lot on my trailer.
Brianv512 is offline   Reply With Quote
Old 10-03-2011, 02:04 PM   #16
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Originally Posted by casarodante View Post
John, I am thinking of putting that on our curved outside wall.
It will take a gentle curve such as your wall in one plane very nicely. There are several styles that have no raised ribs that would curve more tightly.
I didn't show my refrigerator front, but just about everyone who tours the trailer comments on it.
John W. Irwin
WBCCI #9632
Old 10-03-2011, 02:51 PM   #17
ctdair's Avatar
I put Mine up In 2 pieces as that is what I had. I riveted along the seam mimicking the belt line on some trailers. Picture has a lot of flash glare but You can see most of the rivets. The lapped seam is upside down that just was the way it worked out with some damage to one of the pieces I needed to hide.
Name:	Nova Rally 019.jpg
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2010 Dodge 2500 Diesel 4x4 Megacab
ctdair is offline   Reply With Quote
Old 10-03-2011, 04:31 PM   #18
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
I used the Vulcum same as the original skin panels
'77 Sovereign Intl 31' CB
Old 10-03-2011, 04:52 PM   #19
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by dznf0g View Post
Also, in the bath, I would be riveting through the wallboard as well as the interior skin. Is that an issue?
I missed that part. Oops. Good thing you didn't take my advice and start riveting for all you were worth, it could have been--messy...
Old 10-03-2011, 05:15 PM   #20
Pahaska's Avatar
Hays County , Texas
Fridge face
Here is a shot of my refrigerator face with the plastic replica stamped aluminum. The sheets are affixed with double-sided tape and black plastic screen spline is tucked in around the periphery to adjust for the lack of thickness compared to the Dometic panels.
John W. Irwin
WBCCI #9632
Old 10-08-2011, 10:09 AM   #21
dznf0g's Avatar
Oswego , Illinois
Got the backsplash done yesterday. Decided to use 3M super 77 as a contact cement after removing the lower portion of the cabinet.
Worked out fine.
Old 10-08-2011, 11:13 AM   #22
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Worked out fine.
Attachment 142051
Looks really good. Nice job!
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 10-08-2011, 11:46 AM   #23
casarodante's Avatar
2012 31' Classic
Worked out fine.
Very nice. A bit of polishing and you could use it as a mirror! Albeit a bit inconvenient...
Roger & Roxie (rore62) Smith (Air#178 - WBCCI#1646)
On the road!
2012 31' Classic - Nuestra casa rodante
Blog: https://www.casarodante.org - Old Airstream slides: https://airstream.casarodante.org
casarodante is offline   Reply With Quote
Old 10-08-2011, 12:16 PM   #24
dznf0g's Avatar
Oswego , Illinois
It's clear coated exterior skin material, so....no polishing.
Old 11-12-2011, 11:47 PM   #25
Connecticut , USA
Very petty.
I am looking at updating my kitchen area too. Thes look very pretty, and they look easy to clean. are they difficult to install? Thank you for any information on them. I think someone said Home Depot?
Originally Posted by Pahaska View Post
The metal stamped sheets are prone to denting and, once dented, are impossible to repair. You can buy at HD plastic sheets that are practically indestructable and impossible to tell from the real thing. There are edge strips available
I used them as a splash for the wall above the sink at the end of my galley counter and to cover damage on the microwave cabinet. Apply them with double-sided tape. I also used the sheets as the insert on my new refrigerator.
HD stocks a limited number of patterns and colors, but you can order a wide variety from the brochures they have at the display.
DadsGirl is offline   Reply With Quote
Old 11-12-2011, 11:50 PM   #26
Connecticut , USA
Refridge
The pgoto of the refridgerator just loaded, oh my, that is just wonderful!!, Do you slide the squares into the front, and if so how do you ge them to stay put, can you cut them to a size, or will you see gaps? Thank you for any information on this
Old 11-13-2011, 10:43 AM   #27
Pahaska's Avatar
Hays County , Texas
Easy to install with double-sided tape that is sold with them. They cut easily with scissors to fit around objects.
John W. Irwin
WBCCI #9632
Old 11-13-2011, 10:47 AM   #28
Pahaska's Avatar
Hays County , Texas
The photo of the refrigerator just loaded, oh my, that is just wonderful!!, Do you slide the squares into the front, and if so how do you get them to stay put, can you cut them to a size, or will you see gaps? Thank you for any information on this
See the post above. They are installed with double-sided tape and black screen door spline is tucked in around the edges under the plastic of the door. They have weathered several thousand miles and 109 temperatures down to near freezing without shifting or coming loose.
John W. Irwin
WBCCI #9632
Aluminum desk top worksology Cabinets, Counter Tops & Furnishings 33 06-30-2011 05:47 AM
Lug nut torque for aluminum wheels? blickcd Wheels, Hubs & Bearings 5 05-01-2011 08:08 PM
Coated Aluminum glh101282 Clearcoat, Exterior Paint & Trim 6 02-24-2011 10:38 PM
