Old 09-02-2012, 02:30 PM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
How tall is your lip....
How tall above the bottom of the gaucho (where the cushion sits) is the lip that holds the cushions on the gaucho? I'm making that particular piece right now & some of the plans I kind of used have a 6" piece in the front. I just wonder if about 1" or 2" above the bottom is enough to hold the cushion from slipping off? I don't really want a big honking piece sticking up off the edge of the gaucho & would like a little imput...Thanks!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 09-02-2012, 02:33 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Becky, is this for your big trailer, or the little one?
Old 09-02-2012, 02:40 PM   #3
Becky B.'s Avatar
1964 17' Bambi II
The little one. The gaucho is one that slides out on the oak rails & it has (or will have) two or three cushions that lay down to make the bed.
Becky
1964 Bambi II
1988 Avion 32S
Old 09-02-2012, 04:45 PM   #4
1988 32' Excella
Robbinsville , New Jersey
IMHO you would be better off with no lip and use Velcro to hold the cushions on. To me the lip sticking up digs into my legs and gets uncomfortable quickly.
Old 09-02-2012, 05:32 PM   #5
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Becky on our 66 Safari the front board on the gaucho is 3" tall, and sticks up 1" above the pull out plywood.
Barry & Karen
goshawks00 is offline   Reply With Quote
Old 09-02-2012, 06:37 PM   #6
Becky B.'s Avatar
1964 17' Bambi II
Barry & Karen
Do you notice it at all when you are seated on the couch? I was hoping to make it only 1". Does it hold the cushion in place ok?
Thanks both of you for the input!
Becky
1964 Bambi II
1988 Avion 32S
Old 09-03-2012, 02:53 AM   #7
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Yes and yes...
Name:	gaucho pic (Medium).JPG
Old 09-03-2012, 03:46 AM   #8
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
My lip is even with the bottom of the cushion. The cushion is held with sections of 3" velcro sewed to the cushion and glued and stapled to the platform. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 09-03-2012, 05:23 AM   #9
Becky B.'s Avatar
1964 17' Bambi II
The only reason I have reservations about using the velcro, is that you can't ever flip over the cushion to use the other side (if you ever stain the top, or it wears, or whatever). I'm suprised you can feel 1" sticking up on your legs, Barry & Karen! I figured that would be short enough to be unnoticeable! Hummmmmm!
Becky
1964 Bambi II
1988 Avion 32S
Old 09-03-2012, 07:33 AM   #10
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Becky I'm not sure where you are getting your 1" measurement idea from. The wooden glides for the plywood to slip out on are 1-3/4" so the board needs to be at least that tall. Add an 1" to cover the plywood and make a lip above the guides and a 1/4" to cover the bottom profile and you get 3". As far as feeling the 1" lip, no way. The foam supports our legs and is undetectable, same as the dinnette arrangement.
Old 09-03-2012, 07:49 AM   #11
Becky B.'s Avatar
1964 17' Bambi II
I misunderstood your "yes and yes" reply. I thought you COULD feel the lip on your legs. Ok. Now my initial plan will work. The total of my board is around 3 1/2", including the 1" lip. That'll hide the oak glides & sit up above the plywood by 1". Thanks!
Becky
1964 Bambi II
1988 Avion 32S
Old 09-03-2012, 10:36 AM   #12
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
I held the rail flush to the bottom of the glide. and it came out great. Good luck.
Barry & Karen
