Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 06-18-2009, 01:47 PM   #1
bullydogsmom's Avatar
Profile:  1972 25' Tradewind
old mystic , Connecticut
How does this lock?
Just wondering if the table in a 72 tradewind is suppose to have some kind of stop to keep it from swinging when folded up and traveling? Seems like it's going to bang the skin.
Annette
bullydogsmom is offline   Reply With Quote
Old 06-18-2009, 03:05 PM   #2
Commercial Vendor
Profile:  Corona , California
Annette
Airstream did not provide a lock or latch.
You can place a rubber door stop at the bottom.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-18-2009, 10:59 PM   #3
RichHog's Avatar
Houston , Texas
Seems like mine when folded back slides back slightly behind the Gaucho. Mine is on the doorside of the trailer
RichHog is offline   Reply With Quote
Old 06-19-2009, 07:29 AM   #4
Mine is on the streetside under the window.Doesn't go behind the Gaucho.
Annette
P.S. Rich did you get your sink yet?
Old 06-19-2009, 07:50 AM   #5
sd90mac's Avatar
Profile:  1974 31' Sovereign
Cleburne , Texas
Hi,
Ours is under the window street side. We usualy put something in front of the table when traveling to keep it from swinging, but nothing that would damage it, or could slide.
Marie
When people lie to you, and refuse to honor their word, don't regret trying to follow a dream, new adventures and friends await you.
sd90mac is offline   Reply With Quote
Old 06-19-2009, 08:21 AM   #6
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
I have not seen any damage to the skin from swinging free. But I think it is a good idea to take the tables weight off the mounting screws above. I have seen a few of these tables work their way loose. So, I use a wooden wedge to stop the movement and also take off some of the weight.
Pay no attention to the man behind the curtain- WoZ
Old 06-19-2009, 10:15 AM   #7
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
I like Andy's doorstop idea. If you place it under there it will also take a little of the table's weight and transfer that directly to the floor. Otherwise, the rivets that hold the hinge and hold the credenza to the wall will start to sag.
Also, from your picture, I can't tell for sure but your table leaves may not be locked. The bottom looks like it is hanging lower than the top. Those should lock together securely when the table's folded.
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 06-19-2009, 11:05 AM   #8
memgrove2000's Avatar
Profile:  1972 31' Sovereign
Elkhart , Indiana
We use two rubber door stops, As Andy suggested up higher on the page. We use two because the rivets and screws were working loose at the mounting point. I think the stops help transfer the weight to the floor and not the hing. Mike
memgrove2000 is offline   Reply With Quote
Got a new Lock michael13 Doors & Locks 3 11-06-2009 09:06 AM
how does this lock go together? BGS Doors & Locks 0 05-01-2008 03:42 PM
Help with lock please? centennialman Doors & Locks 10 07-06-2006 06:45 AM
Does anyone use this lock? azflycaster Buyer Guidelines 12 11-24-2005 10:20 AM
That @#*# Lock niftypkg Doors & Locks 16 11-20-2005 03:28 PM
