Old 05-24-2010, 05:25 PM   #1
1977 29' Ambassador
Union , Mississippi
How best to repair the Roof locker assy.
Hello to all.
I have a 1977 AS 29' Ambassador and need some advice. The roof locker that houses the Central control unit has a couple of rivets pulled out of the end cap and also one pulled out of the window trim as the attached photos show.
Want to know the best way to fix this? I have a rivet tool and rivets. Wondering if I need to try to put a rivet back where one came from or drill a new hole and place one there instead. As you will notice from the attached photos some of the plastic is gone from where the rivet is supposed to be.
Katman104 is offline   Reply With Quote
Old 05-24-2010, 06:48 PM   #2
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant , South Carolina
Katman,
I would re-rivet back into place but I am more curious as to why did it come loose?
Are you losing any other rivets elsewhere on the interior? If so, could be worn out axles--many threads out there on this.
I notice in a picture that there is a turned, wooden post holding up the end of that cabinet and the rivets have pulled loose from the post end of the cabinet. Wonder if that post holds the outside of the cabinet in such a rigid position so that as the trailer moves down the road and flexes it doesn't allow for natural movement of the cabinet with the ceiling. The natural flexing would bring the ceiling and the floor slightly closer together and then back--over and over. That post doesn't allow the slight compression in that area. Could that process be slowly pulling the cabinet rivets out over the last 30 years?
Just a thought.
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 05-25-2010, 06:05 AM   #3
1977 29' Ambassador
Union , Mississippi
Cantrell
Thanks for your response.
The axles have been replaced by previous owner recently. I bought this unit in November 2009.
There are no more rivets out anywhere that I see. I also wondered if this post is a factory thing or something that was added later by someone. The Central Control Cabinet is also in the cabinet at the far end from the post and seems to be to heavy for the plastic bottom which causes it (the bottom) to pull away a little from the sides of the cabinet. Anyone else out there that has the same setup in their AS 29' Ambassador?
Old 05-25-2010, 06:29 AM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Katman,
Hi from N. Mississippi. Could be damage from before the new axles were installed and also from the PO putting too much weight in the overhead. You should be able to pop rivet it back. It the hole is not rounded out you can use 1/8" rivets but it is is wallowed out you may have to go to 3/16. Also there are different grip lenghts on the rivets and the short ones may not be long enough. HD or Lowes should have both (make sure you get the aluminum shank rivets and not the steel). Good thing about pop rivets is if you mess one up, just drill it out and try again
Old 05-28-2010, 06:47 AM   #5
1977 29' Ambassador
Union , Mississippi
Thanks for the reply's. The question I have now before I re-rivet is this " does anyone else on the forum have a 1977 AS 29' ambassador that has a post under the cabinet like image IMG1839A. I am wondering if this was added by someone or if it came like this from the factory? If you have a unit like this please post. Thanks
Katman104
Old 05-29-2010, 05:29 AM   #6
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Katman104
That post appears to have been added. See here:
77Ambassador
The pic 1838A - I'd move out and inch or so on each side and add two rivets to that area. You can buy the white prepainted rivets if you look around.
Old 05-29-2010, 07:18 AM   #7
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
77Ambassador
I agree on both.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Roof gel coat repair? Don Boyd Sprinter and B-van Forum 4 02-25-2010 07:59 AM
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 10:24 PM
roof locker latch help goransons Cabinets, Counter Tops & Furnishings 5 02-21-2008 01:19 PM
Roof Locker Latch for '66 Overlander draftwomyn21 Cabinets, Counter Tops & Furnishings 0 08-31-2006 03:39 PM
Roof locker extrusion needed mcneon Cabinets, Counter Tops & Furnishings 1 09-24-2004 09:00 AM
