Old 03-30-2015, 02:46 PM   #15
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
So for you Fiberglassing Gurus out there, I have been trying to figure out which product to buy, and came across the SMC Fiberglass Resin made by Evercoat, vs. the West Marine Epoxy based fiberglass resin. Both are available to me locally with the Evercoat being the more pricey (surprisingly). Any further recommendations. Is ABS truly an SMC (Sheet Molded Compound)? The description of SMCs at the site below makes me wonder whether it is...
Fiberglass and Composite Repair | Fibre Glast
Old 03-31-2015, 10:44 AM   #16
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
What I can say about SMC is that it dries less brittle than standard polyester resin and it adheres (much) better to any surface I have applied it to.
I have not used it on ABS, but I have used it on the back of flexible bumpers where I would not use polyester resin.
ABS should hold it better than the bumpers, especially if sanded WELL with 80 grit or more course media.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 04-05-2015, 09:05 AM   #17
mrrealtor's Avatar
1972 31' Sovereign
Racine , Wisconsin
There is a company called Bath Fitter that does the same thing.
1972 Airstream International Land Yacht Sovereign
mrrealtor is offline   Reply With Quote
Old 05-13-2015, 10:17 AM   #18
1976 31' Sovereign
Apache Junction , Arizona
I talked to a repair shop about my shower / tub and they recommended fiberglas mesh or fabric but to use two part epoxy instead of resin. I have not tried that yet. Good luck.
plbalza54 is offline   Reply With Quote
Old 05-13-2015, 03:36 PM   #19
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
Two weeks ago we got back from Algonquin and I noticed a hole in our tub. The culprit was a lawn chair. Went to local Rv shop and picked up some Devcon , fiberglass, porcelain and plastic repair kit. Its a 2 part epoxy resin with fibre glass mat. 1500 psi strength. Worked great. A little runny and gets hot to the touch when mixed. 5 min handling time, 20 min set and 24 hr cure time. Hope this helps.
Cyquest is offline   Reply With Quote
Old 05-14-2015, 05:12 AM   #20
1973 31' Sovereign
FLORIDA , Florida
I need to refinish my tub in my 1973 air stream it was stained bad from well water over the years I removed the tub and sink and surround very easy it has pop rivets under a trim with a plastic insert. Which I have not found yet to replace. Its vinyl insert. I repaired and sanded the tub went to lowes or home depot and bought a kit with two large cans of one step epoxy and refinished it. I cant believe how it looks and the finish is very durable. It would be the best way to repair from under side
Davidlee is offline   Reply With Quote
Old 05-14-2015, 09:35 AM   #21
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
A fiberglass boat repair place might be able to fix it for you too. They have all the right toys and materials, and can cover with gelcoat when done. Better than new....and nearly bulletproof
NavyCorpsman is offline   Reply With Quote
sovereign
'77 Sovereign Tub silveysd Sinks, Showers & Toilets 0 07-11-2011 08:09 PM
Hole in tub mwells4654 Sinks, Showers & Toilets 12 09-16-2010 09:22 AM
Heat Duct Assembly Mystery Hole Under Tub cadoc Furnaces, Heaters, Fireplaces & Air Conditioning 1 10-09-2008 10:56 AM
Leak in closet between bed & tub in '75 Sovereign. kidless 1974 - 1979 Sovereign 7 09-07-2008 08:53 AM
tub p-trap Paul Mayeux Sinks, Showers & Toilets 7 02-19-2003 11:24 AM
