Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 10-08-2004, 09:20 AM   #1
Profile:
hinges on wardrobe losen
I'm having a problem with the hinges always coming lose on the wardrobe cabinet. Are there any suggestions on how to keep them from coming lose? I just read an article on Euro hinges and I'm wondering if I should try to use these in place of what came with the Safari.
bfwoz is offline   Reply With Quote
Old 10-08-2004, 09:33 AM   #2
TomW's Avatar
Profile:  1967 26' Overlander
Huntsville , Alabama
Running gear balance
Bob,
A different style hinge may help alleviate the symptoms, but check this thread for insight into the problem. Post #16 in the thread appears to parallel your issue. BTW, RivetED is aka Ed & Debbie.
Tom
Old 10-08-2004, 02:12 PM   #3
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 13
Safari cabnetry
The Safari cabinets are what Airstream terms "light plywood", as were the cabinets in my 2003 International AS. This plywood is amazingly light, but it does not hold screws well, especially if they have ever been removed and replaced once.
I poked toothpicks dipped in glue in some of my loosest screw holes and it helped a lot. Worst case, drill a 1/4" hole partway through the door and glue in a piece of 1/4" birch dowel. Pre-drill the screw holes in the dowels so that the dowels do not split.
I might suggest that a set of Centramatic balancers will reduce the vibration that loosens things in the trailer.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2007 Silverado 2500HD Duramax/Allison LTZ
WBCCI Region 9 Webmaster, #9632
Old 10-08-2004, 03:53 PM   #4
Profile:
hinges
John
The last thing I was have guessed was a vibration problem, I assumed that the trailer gets bounced around on the road. What type of hinges did you use?
Old 10-08-2004, 03:58 PM   #5
Pahaska's Avatar
Images: 13
Hinges
Originally Posted by Bob Wozniak
John
I just used the hinges that came on the trailer and tried to reinforce the holes in the lightweight plywood. I didn't see any problem with the hinges ... just the holes in the weak plywood.
As far as balancers go, I no longer have screws on light fixtures looseniung, so it should help equally with screws in the wood.
John W. Irwin
Old 10-08-2004, 07:04 PM   #6
Profile:  1975 29' Ambassador
Reno , Nevada
Good idea!
screws don't come loose without something working on them Trailer wheel hubs aren't known for being balanced and have caused other problems. See Andy's (inlandrv.com) thing on balancing. The Centramatic balancers seem to be a better solution.
How to refasten door hinges! pipsmith22844 Doors & Locks 14 03-16-2004 07:17 AM
Exterior Door Hinges HowieE Doors & Locks 3 08-25-2003 02:49 PM
dor hinges wb13798 Mechanics Corner - Engines, Transmission & More... 13 02-05-2003 07:36 PM
Exterior Door Hinges LKappenman Doors & Locks 24 01-23-2003 09:49 PM
Wardrobe Removal ??? 54FlyingCloud General Interior Topics 1 07-25-2002 03:22 PM
