Old 07-28-2014, 07:49 AM   #1
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
Victoria , British Columbia
Help need to find this part for flip out table
Can anyone tell me who would carry this part . I am finishing the build of my dinette conversion to recliner and flip out table and need this part to complete. It is a clasp that holds the two table sections together while stowed. I have check most cabinet hardware sites online and can find nothing . Any suggestions ?? Thank you .
Name:	Table Latch.jpg
LAWBC is offline   Reply With Quote
Old 07-28-2014, 07:51 AM   #2
dznf0g's Avatar
Oswego , Illinois
It may be an AS only part. I'm sure your dealer can help.
-Rich-
Old 07-28-2014, 07:56 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
check Rockler web site.
Old 07-28-2014, 08:43 AM   #4
1981 31' Excella II
New Market , Alabama
The closest thing I could find is this. From the photo, I don't see you need a lock. Gravity will keep it folded.
Shop metal hook box latches online Gallery - Buy metal hook box latches for unbeatable low prices on AliExpress.com
Perry
Old 07-28-2014, 08:49 AM   #5
dznf0g's Avatar
Oswego , Illinois
Perry
I needs to be there while folded and stowed to keep from flopping open.
-Rich-
Old 07-28-2014, 09:13 AM   #6
1981 31' Excella II
I have that latch on my big table but my table stows in the vertical position where the leaves can unfold. This table looks like it stows in the horizontal position maybe even with a cushion on top of it. Unless the photo is rotated, I don't see it.
Perry
Old 07-28-2014, 09:16 AM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
It doesn't look like a lock, more like a blind hinge that allows the panel to roate 180 from open to closed, that has the unique feature that when the panel is open, the top of the table is completely flush, no hinge visible.
Table leaves that fold up instead of folding down are uncommon, and I can't think of a source that has hinges like that.
But if you wouldn't mind a hinge sticking up slightly, then just using an ordinary piano hinge instead would work fine.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-28-2014, 09:31 AM   #8
dznf0g's Avatar
Oswego , Illinois
It appears to me that OP is modeling the same configuration as OEM late model AS. The hinge that protagonist speaks of is attached to the lower panel and is up under the "shelf".
Here's mine:
-Rich-
Old 07-28-2014, 12:29 PM   #9
1981 31' Excella II
That is exactly how mine looks. Those hook latches that I posted should work as long as the hook is located such that it points down.
Perry
Old 07-28-2014, 12:35 PM   #10
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I would like to find that part as well.
We completed our dinette removal/ recliner upgrade as well.
The hook is the last part I need.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 07-28-2014, 01:34 PM   #11
LAWBC's Avatar
Here's mine:
Attachment 217629
Attachment 217630
Attachment 217631
That is it, but where?
Old 07-28-2014, 01:54 PM   #12
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Don't know if this would work but...
I was thinking/planning to modify my dinette table and got a great suggestion from another member. Look at post 2 or 3. A Soss Hinge might work just as well or better.
http://www.airforums.com/forums/f38/...on-115227.html
Old 07-28-2014, 02:22 PM   #13
dznf0g's Avatar
Oswego , Illinois
I think there is some confusion on this thread. If you are looking for that spring loaded wire bail hook, I have never seen one except on an AS. Call your dealer (or any dealer) and have them drop ship one to your door.
Perry shows some hooks which, if they are the right size, would work.
-Rich-
Old 07-28-2014, 11:32 PM   #14
LAWBC's Avatar
Got it , the parts list to make this clasp
So I was talking to the carpenter where I work and he looked at the picture of the clasp , and said "you know you can do a lot with a nail ". and the light went on , how he describe
Parts are ;
one nail to be bent to match as described in the photo
one small spring goes onto the nail to the head side to supply tension.
one piece on metal flat stock , can use anything like common straight bracket, cut to shape, bore appropriate holes
one brass grommet to be the receiver side of the clasp Nail now cut to size.
I have the parts just need the time , working on the sliding frame for now , hope to get this table assembled next week or two and I post pics when done
Flip Up Table twostickdogs Airstream Classifieds 0 04-08-2014 08:51 AM
I need help with naming a part and figuring out how to use it. jgermano General Repair Forum 2 02-02-2014 08:52 PM
Where to find out of production Reese Trunion part no. 58028 PARKS1963 General Repair Forum 5 06-25-2013 12:33 PM
Need flip up side table for 1973 Argosy kimslat Cabinets, Counter Tops & Furnishings 0 05-12-2010 01:07 AM
Weight distribution flip clip issue Boondocker Hitches, Couplers & Balls 6 02-17-2006 08:44 AM
