07-28-2014, 07:49 AM
2013 27' FB International
2012 23' Flying Cloud
GVA
, British Columbia
Help need to find this part for flip out table
Can anyone tell me who would carry this part . I am finishing the build of my dinette conversion to recliner and flip out table and need this part to complete. It is a clasp that holds the two table sections together while stowed. I have check most cabinet hardware sites online and can find nothing . Any suggestions ?? Thank you .
07-28-2014, 07:51 AM
Oswego
It may be an AS only part. I'm sure your dealer can help.
-Rich-
07-28-2014, 07:56 AM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
check Rockler web site.
07-28-2014, 08:49 AM
Oswego
Originally Posted by perryg114
I needs to be there while folded and stowed to keep from flopping open.
-Rich-
07-28-2014, 09:13 AM
1981 31' Excella II
New Market
, Alabama
I have that latch on my big table but my table stows in the vertical position where the leaves can unfold. This table looks like it stows in the horizontal position maybe even with a cushion on top of it. Unless the photo is rotated, I don't see it.
Perry
07-28-2014, 09:16 AM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
It doesn't look like a lock, more like a blind hinge that allows the panel to roate 180° from open to closed, that has the unique feature that when the panel is open, the top of the table is completely flush, no hinge visible.
Table leaves that fold up instead of folding down are uncommon, and I can't think of a source that has hinges like that.
But if you wouldn't mind a hinge sticking up slightly, then just using an ordinary piano hinge instead would work fine.
07-28-2014, 09:31 AM
Oswego
It appears to me that OP is modeling the same configuration as OEM late model AS. The hinge that protagonist speaks of is attached to the lower panel and is up under the "shelf".
Here's mine:
-Rich-
07-28-2014, 12:29 PM
1981 31' Excella II
New Market
, Alabama
That is exactly how mine looks. Those hook latches that I posted should work as long as the hook is located such that it points down.
Perry
07-28-2014, 12:35 PM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
I would like to find that part as well.
We completed our dinette removal/ recliner upgrade as well.
The hook is the last part I need.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
07-28-2014, 01:34 PM
GVA
, British Columbia
Originally Posted by dznf0g
That is it, but where?
07-28-2014, 01:54 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Don't know if this would work but...
I was thinking/planning to modify my dinette table and got a great suggestion from another member. Look at post 2 or 3. A Soss Hinge might work just as well or better.
http://www.airforums.com/forums/f38/...on-115227.html
07-28-2014, 02:22 PM
Oswego
I think there is some confusion on this thread. If you are looking for that spring loaded wire bail hook, I have never seen one except on an AS. Call your dealer (or any dealer) and have them drop ship one to your door.
Perry shows some hooks which, if they are the right size, would work.
-Rich-
07-28-2014, 11:32 PM
GVA
, British Columbia
Got it , the parts list to make this clasp
So I was talking to the carpenter where I work and he looked at the picture of the clasp , and said "you know you can do a lot with a nail ". and the light went on , how he describe
Parts are ;
one nail to be bent to match as described in the photo
one small spring goes onto the nail to the head side to supply tension.
one piece on metal flat stock , can use anything like common straight bracket, cut to shape, bore appropriate holes
one brass grommet to be the receiver side of the clasp Nail now cut to size.
I have the parts just need the time , working on the sliding frame for now , hope to get this table assembled next week or two and I post pics when done
07-29-2014, 06:24 AM
1981 31' Excella II
New Market
, Alabama
It is not that complicated.
Perry
08-10-2014, 01:26 PM
GVA
, British Columbia
Installed new fold out table w/o clasp for now
Finished and installed new flip out table , but left the clasp out for later . After seeing the table installed we felt that the table would be just fine in a open position even for traveling .The table and leaf weight 20 plus lbs. and I do have bull dog clasps at the end of the rails to hold it in position though rolling down the highway one never knows the g forces .
Anyway built it a bit different from most other tables, Formica over 5/8 Baltic birch ply ,and that gave me a lot of grief namely hardware that I could not use because it wasn't 3/4 stock and so had to toss the Soss hinges for the 180 fold over hinge (and they are not as tight ). The fold out leg is like the original table it is by Hafele , the sliding frame is a modified part from Lee Valley (wood table extension slides )
One added feature is the 120V with USB ports attached to the cabinet then plugged into the lower outlets on the trailer regular or inverted side .
Another mod was to add 1/2 "ply over the street side settee extending it 4" out , thus eliminating the sensation of rolling off when seated .
After doing the project in Formica I would suggest wood only as it is the easy and only way to go.( Formica = glass)
Oh did I mention the chair in brown leather, OMG is it comfortable!!!
SPACE 27.70 - IMG
Thanks to Russ and Linda "Luckyducks " for the inspiration for this project made the trailer more destination .
08-10-2014, 04:59 PM
1981 31' Excella II
New Market
, Alabama
I leave my table in the upright position all the time and it travels better that way.
Perry
